Single precision better than double precision? |
July 30, 2015, 01:08 |
Mike
I am running a basic simulation with water flowing at about 0.3 m/s through a 20 m pipe. I have very small protrusions embedded in the pipe that are only a few millimeters in height, width, and length. I am only interested in the pressure drop along the pipe and I get very different results depending on if I use single precision or double precision. I am new to Ansys but I am assuming that the double precision results are more accurate and I should just use those. Am I correct in thinking this or could the single precision results actually be more accurate? Also, should double precision always be used so long as the longer computational time is of no concern?
Thanks in advance for the help! |
July 30, 2015, 02:32 |
Rep Power: 144 |
Double precision will always be more accurate. If single precision is more accurate then this is simply a one-off chance as random noise has tried to confuse you.
But double precision requires more memory and a longer simulation time (assuming convergence is the same as a single precision simulation). Whether the longer simulation time and additional memory requirements are a problem is up to up. At least you have the choice. |
ansys 15.0, cfx, fluid flow, precision |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
Continuing User Defined Real Gas Model issues | aeroman | FLUENT | 6 | April 8, 2016 03:34 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
what's wrong about my code for 2d burgers equation | morxio | Main CFD Forum | 3 | April 27, 2007 10:38 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
