July 27, 2015, 13:33 |
Continuing a crashed TBR simulation
Arman Farhanieh
Dear All,
I started a TBR (Transient Blade Row) simulation (Time Transformation, CFX v15 Beta module) on of a turbine about week ago, and just Before the simulation had finished, it crashed so it didn't create any .res file. I copied the .bak file to my computer to check the results, but othere data such as mesh were not saved. I noticed that in the folder where the .bak and all other files are saved, there is a file with a random name (zFas3A4b) that is extremely huge in size, which must be where all transient data has been saved. My first question: Is there a way to continue the simulation from the .bak file? Second: Is there a way to export the .res? Thank you all |
July 27, 2015, 14:58 |
Rep Power: 33 |
Try renaming the file to MyResults.res, and see if CFD-Post can open it, and post-process it.
There is the cfx5export command line, or in the CFX-Solver Manager look at the Tools/Export Results menu. |
July 28, 2015, 08:08 |
Arman Farhanieh
Dear Opaque,
Thank you for your response. At first I thought adding .res to the end of that file had helped since I could open it and all time steps were there. However, when I checked some of the results, it crashed. I also looked at Tools/Export you mentioned, there was nothing about exporting a .res file there. Is there any other way to export or maybe just continue running the simulation by having the "run directory"? Thanks |
Huge file sizes when Running VOF simulation | aarratia | FLUENT | 0 | May 8, 2014 13:27 |
Supersonic Nozzle Exhaust Simulation | mikeh | FLUENT | 0 | May 1, 2014 22:28 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 11:44 |
Star crashed with spray simulation, please help! | Jimmy Fox | Siemens | 4 | October 17, 2006 17:09 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 11:06 |
