July 27, 2015, 01:51 |
setting heat flux inlet boundary condition
tushar
Rep Power: 11 |
hi every one, can we set inlet boundary condition as heat flux or heat loss by any means like udf or anything else?
July 27, 2015, 06:39 |
rasool
Rep Power: 13 |
yes
look at tutorials |
July 27, 2015, 11:04 |
Rep Power: 33 |
Would you mind being more specific ? Specification of heat flux at an inlet is not a common boundary condition in the heat transfer literature (assuming is even possible)
At inlets, there is more than heat flux crossing the boundary; therefore, a flux condition should include more than just heat. What are your modeling requirements ? or what are you trying to model ? The better the description, the higher the chances someone in the forum may pitch in. |
July 28, 2015, 02:01 |
#4 | |
tushar
Rep Power: 11 |
actualy i am optimizing heat exchanger for mass...now i want to study, what is performance of heat exchanger if we increase or decrease heat input to heat exchanger, in that sense i want heat (watts) as input BC. |
July 28, 2015, 02:06 |
Rep Power: 144 |
The heat input in the fluid entering the heat exchanger is from the temperature and specific heat of the fluid - so you define the temperature of the fluid entering. No need to define a heat flux, the heat flux is inherent in the specification of the temperature.
July 28, 2015, 02:18 |
#6 | |
tushar
Rep Power: 11 |
thanks for reply i have done simulation in same way u said. but heat exchanger is with large electric motor, and whole system simulation takes longer time...to reduced time, i want heat as input BC. (to get temperature at inlet, i need to run whole system and that i don't want)..Reply? |
July 28, 2015, 09:50 |
Rep Power: 33 |
I understand what you are modeling now. Still your use of vocabulary is confusing. In my vocabulary, heat is due to temperature gradients (like k. grad T), or friction (irreversible work) not energy transport by fluid motion.
Have you looked at the Total Enthalpy boundary condition ? At inlets, the contribution to the energy flow (transport plus conduction) is dominated by the transport (mass flow, Cp, and Temperature); therefore, there is no need for a flux boundary condition. |
Divergence:Temp with heat flux boundary condition | asutoshpadhy | FLUENT | 0 | April 26, 2015 05:18 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 21:11 |
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 18:15 |
constant heat flux boundary condition | manoj_1 | Phoenics | 0 | June 27, 2010 14:07 |
