Immersed Solid linked to Rigid Body Solver Query
Old   July 24, 2015, 08:57
Default Immersed Solid linked to Rigid Body Solver Query
Gavin
Minty688 is on a distinguished road
Hello All!
I come to humbly ask for some assistance in this issue I have come across.
Simply put I have a ball passing through a gradual 90 degree elbow pipe, and I am using Ansys CFX. The expectation is for the ball to bump against the wall of the pipe on its way through but to remain inside the fluid domain.
The ball itself is a domain on its own set as an immersed solid linked to a rigid body solver. Standard inlet and opening conditions on the two ends of the pipe, default wall conditions elsewhere. With this I end up having the ball start moving along the pipe as expected until it reaches the bend where it passes through the wall and off into space.
I have tried fiddling with different settings put to no avail. Does anyone know what I might be doing wrong or have you got a method for doing this problem yourself?
Best Wishes,
Minty
Minty688 is offline   Reply With Quote
Old   July 24, 2015, 12:00
Edmund Singer P.E.
singer1812 is on a distinguished road
CFX doesnt have wall to wall interference built in.
singer1812 is offline   Reply With Quote
Old   July 24, 2015, 21:51
You could either do this as a FSI model with ANSYS mechanical's contact model or if your boundary is simple you might be able to define some CEL expressions to prescribe the wall locations and influence the rigid body velocity.
ghorrocks is online now   Reply With Quote
Old   July 28, 2015, 07:47
Gavin
Thanks Ghorrocks, I'll give that a go.
interDyMFoam - One rigid body, multiple boundaries mattkram OpenFOAM Running, Solving & CFD 1 March 29, 2021 09:36
Rigid body motion on transient fluent mrf ghost82 EnSight 4 September 6, 2014 12:24
On the alpha Eqn of VOF method when using Immersed boundary method in OpenFOAM keepfit OpenFOAM 4 January 31, 2014 15:32
Re-meshing a deformable solid body in a fluid brashear CFX 6 December 12, 2011 12:13
Turbulent solver rigid body mechanics philippose OpenFOAM Running, Solving & CFD 53 July 16, 2011 14:35
