Error when exporting 3D mesh from pointwise to cfx |
Rory
Rep Power: 0 ![]() |
I wanted to practice generating a 3D mesh in pointwise and exporting it to cfx for further analysis. To do this I first attempted exporting the CAE mesh from the Boeing 747 Nacelle tutorial in pointwise. I set the solver to ansys cfx, reset the boundary conditions, selected the three blocks and exported it to a .grd file. However, when I try importing the mesh to cfx I get the error: "Unable to import mesh: No 3D elements imported". I can't seem to find a solution to this problem and any help would be greatly appreciated. |
Jack
Rep Power: 11 ![]() |
I am also having the very same issue...
Rep Power: 143 ![]() ![]() ![]() ![]() |
The CFX error says means that is cannot read the file. You are going to have to find a file pointwise can export which CFX can read. It looks like the default CFX gizmo in pointwise does not work so you are going to have to try something else. Maybe CGNS, or any of the other formats.
Rory
Exporting the .grd from pointwise is fine. All you need to do is make sure that when you import the mesh in CFX, make sure that the Files of Type option is set to Pointwise Gridgen.
Jack
Thanks for your responses. Exporting to .cgns format worked fine for CFX.
cfx 15, pointwise |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
Does CFX have a button to refine the mesh? | lnk | CFX | 2 | July 27, 2012 16:02 |
[ANSYS Meshing] Question about ICEM mesh output to CFX | lnk | ANSYS Meshing & Geometry | 0 | July 27, 2012 15:39 |
CATIA: Exporting mesh to CFX | Jan | CFX | 1 | November 28, 2006 07:15 |
