Output results NOT saved in CFX-POST
Old   July 17, 2015, 22:06
Exclamation Output results NOT saved in CFX-POST
Riyal
Riyal is on a distinguished road
Hello all,
I am an Ansys beginner who has been trying to do some tutorial examples with this software. I have been able to run the software successfully to model my problem. However I have not been able to use the option "Save Picture" in CFX-POST to output the image file of the model I processed. Also the button called "Publish" which allows a report of the simulation to be output as HTML file, also does not work. In the save file window, it shows that a file is created but when I check the same folder in windows explorer, the file does not exist. I have already checked whether I have set any file to "hidden" mode.
However, it is possible to get the Picture as output from CFX-Pre without any trouble.
Could someone please help me to solve this problem? Thank you very much in advance.
Riyal is offline   Reply With Quote
Old   July 18, 2015, 07:11
It is puzzling, isn't it? I think "save picture" just puts a picture in the report, so when you produce a report that picture is included.
The option you are looking for is "save image to file". This saves the current display to an image immediately.
Old   July 19, 2015, 00:22
Riyal
Yes it is puzzling! I have been stuck with this problem for a while now. The problem is that the file saved from Post processing software is not really saved in the hard disk. I checked whether the hard disk is write-protected, but it is not.
Any body knows why this could happen?
Old   July 19, 2015, 08:08
My previous post explained what is happening. "Save Image" just puts an image in the report which gets generated when you generate a report. It does not save an image to disk immediately. "Save Image to File" is the option to save the image to file immediately.
Old   July 19, 2015, 23:42
Riyal
Thank you for your reply. But the problem is not solved.
I have checked thoroughly, but I do not see a "Save Image to File" option in Ansys 15 CFD-CFX. There is an option to publish a report, but this only produces an output file when I have not done any simulations.
Old   July 20, 2015, 00:30
Oops, I got mixed up between ANSYS Mechanical and CFD-Post. The option I was talking about is in ANSYS Mechanical.
In CFD-Post the option you are looking for is under the File menu - "Save Picture".
ansys 15.0, cfx 15
Transient Run - Output "Time" in partial results? evcelica CFX 2 May 16, 2012 22:36
Doubt in CFX post results shaswat CFX 1 April 14, 2012 12:22
Proper output of angle of attack in CFX post Kevin CFX 3 October 18, 2006 13:18
CFX load Results file furkan CFX 2 August 24, 2006 08:18
(CFX POST) Rotational Speed ARJUN CFX 9 July 13, 2006 21:38
