Theory question about suction pressure of a pump and CFX Simulation
Old   July 11, 2015, 21:30
Default Theory question about suction pressure of a pump and CFX Simulation
ivan
iloc86 is on a distinguished road
Hi guys, im in a research project about artificial lift systems for oil wells. we are discusing about put a pump in surface and its capacity to lift the oil. As all we know, in atmosferic conditions, if we have a vertical pipe that in the bottom we have a tank of water and in the end we have a pump, the maximum heigh that we going to lift is nearly 10.3 m cuz is what 14 psi of the atmosphere pressure can lift if we get near to zero pressure at the outlet.
I did in cfx a 20m vertical pipe, where in the inlet (bottom) have 1 atm and in the outlet have 1 atm, and i did a subdomain with general momentum source to v=1 m/s, that simulate the pump near the end of the pipe. i got convergence and i found that it flows, i was waiting no convergence cuz in realit it can flow with that conditions. Whats going on??
iloc86 is offline   Reply With Quote
Old   July 12, 2015, 07:11
Please post some images of what you are modelling, your mesh and your CCL.
Old   July 13, 2015, 11:45
Default pictures
ivan
i hope it could help
Old   July 13, 2015, 19:56
You have not included your mesh or CCL. I do not know what the images mean without it.
Old   July 16, 2015, 19:21
Steffen595 is on a distinguished road
put an expression in for AreaAve(Pressure)@outlet
or better still outlet - inlet? Or both, see, what they are up to
Steffen595 is offline   Reply With Quote
cfx, pump, suction
Convergence issues for a 3D Centrifugal pump simulation using ANSYS CFX enr_venkat CFX 7 August 31, 2016 19:58
Small cluster configuration for pump simulation at CFX Nevel Hardware 2 April 7, 2014 07:07
Pump simulation result validation enr_venkat CFX 9 January 15, 2014 01:04
Small cluster configuration for pump simulation at CFX Nevel CFX 3 February 3, 2010 23:37
Pump Station Simulation GUSU CFX 6 October 14, 2009 07:40
