July 10, 2015, 15:20 |
CFX – AIR Real Gas – Library
Farbod Vakili
I want to Select material , As AIR Real Gas in CFX .
I searched the Library (PENG ROBINSON . redlich kwong ) , for the Air Real Gas Material , but I couldn’t find that . (I have found many other materials , but not air , which is strange !) By Selecting The Equation of state as real gas , they are some properties of air which are blank like (Cp , Critical Properties ) . I know I can write the properties by myself . But I was wondering , why CFX doesn’t provide the properties of this very common material ,Air , in the library . I appreciate your help with that , |
July 11, 2015, 07:15 |
Rep Power: 144 |
I suspect this is because air is a mixture and therefore not a Peng Robinson material. Try using a multicomponent mixture of nitrogen and oxygen (and the trace stuff if you want super accuracy but are willing to add some more complexity)
July 15, 2015, 12:31 |
Farbod Vakili
Yes , Air can be modelled by Multicomponent .
But , CFX , provide the properties of Air , as Ideal Gas , but not the properties as the Real gas . So , maybe it is not because of being mixture and there is somewhere inside that I cannot find that . |
July 15, 2015, 20:34 |
Rep Power: 144 |
Well keep hunting then. I think my previous post explains exactly why you cannot find it.
air, cfx, material library, real gas |
Parallel User Defined Real Gas Model | aeroman | FLUENT | 4 | July 1, 2015 07:09 |
How to use real gas as fluid domain in CFX ? | badboyz31 | CFX | 5 | September 24, 2014 19:37 |
Gas dispersion in air error message | redhoax | OpenFOAM Running, Solving & CFD | 27 | October 25, 2013 06:31 |
Problems in air flow udf - divergence | PJT | Fluent UDF and Scheme Programming | 0 | May 28, 2013 11:01 |
view factor | yoollooz | Fluent UDF and Scheme Programming | 0 | March 1, 2013 01:44 |
