homogeneous binary mixture
Old   July 7, 2015, 12:41
Default homogeneous binary mixture
niru
Niru is on a distinguished road
I want to model the vaporization of liquid methane to methane vapor. As and when heat is methane liquid, it should get converted to vapor.
If I chose the peng robinson wet refrigerant of methane ch4vl (homogeneous binary mixture) , will I be able to model this phenomenon.
Or should I add, CH4 vapor seperately and CH4 liquid separately.
Which material should I chose?
Niru is offline   Reply With Quote
Old   July 7, 2015, 19:23
Opaque will become famous soon enough
You load the 3 materials: CH4vl, CH4l, CH4v.
You add fluid to your domain, and select the binary mixture for the material in the fluid, i.e. CH4vl.
Summary: you are modeling the binary mixture as a fluid in the domain. For thermodynamic calculations, the software needs to know the information of each thermodynamic state separately.
Hope the above helps,
Opaque is offline   Reply With Quote
binary mixture, ch4
[Resolved] GPU on Fluent Daveo643 FLUENT 4 March 7, 2018 09:02
Error in solution using "Grid Interface" agustinvo FLUENT 4 January 20, 2015 13:03
how to set Boussinesq model for homogeneous binary mixture richard2000 CFX 3 September 14, 2010 04:04
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 09:42
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 16:52
