fatal linear solver overflow
Old   July 2, 2015, 07:30
Default fatal linear solver overflow
hani mortezaee
h.mortezaee is on a distinguished road
hi everyone
im modelling a closed enclosure with cylindrical shape with 7 atm nitrogen gas inside and 3 energy point source in the middle , my mesh is fine my time step is 1e-5 even when i model it with laminar option i get a fatal linear solution overflow , i dont know why , can anyone help me ?
i can provide more information about the simulation if you wanted ,
thank you
h.mortezaee is offline   Reply With Quote
Old   July 3, 2015, 09:11
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
1) If it's a closed system how do you know it's 7 atm pressure? Did you set the pressure level information in -> solver control -> advanced options -> pressure level information?
2) Is your source term correct? Have you provided a suitable linearization coefficient? Read up on source term linearization by Suhas Patankar in Numerical Heat and Fluid Flow.
3) How do you know your mesh is fine? This is very subjective.
JuPa is offline   Reply With Quote
Old   July 3, 2015, 11:35
hani mortezaee
my mesh statistics are fine , and yes i set pressure level information , problem is solved my initialization was wrong , its now converging and the result are good , thanks rico for your reply
Fatal overflow in linear solver error. Why? zaidun CFX 7 August 11, 2016 06:59
Fatal overflow in linear solver alinik CFX 21 February 29, 2016 17:43
2D isothermal cylinder not converging UPengineer OpenFOAM Running, Solving & CFD 7 March 13, 2014 06:17
time consuming of the linear solver luckycfd OpenFOAM Programming & Development 3 September 23, 2013 06:29
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 02:23
