Rotational porous domain
Old   June 30, 2015, 11:36
Default Rotational porous domain
Pif Poffele
Pifpoffele is on a distinguished road
Hi all,
I have a question. If i have a model f.e. a duct which includes a porous domain as part of the duct and a pressure drop between the openings of the duct, so I will get a mass flow.
If i set porosity of the porous domain part to 1 and the loss coefficient to 0 .... I get the same results as i will set the porous domain as fluid domain (which sounds logical)
But if I set the domain motion to rotational with any angular velocity, axis definition and frozen rotor boundary setting, the result of the porous domain case (where one part of the duct is set to porous domain with porosity 1 and loss coefficient 0) differs from that one I get with the simple fluid domain case (where all parts are fluid domains).
In other words, if I include a porous domain in any model with porosity 1 and loss coefficient 0, why can there happen anything different as if I would set the domain to fluid domain ??
Can anyone help me by that?
Thank you, best regards,
Christoph
Pifpoffele is offline   Reply With Quote
Old   July 6, 2015, 12:46
Pif Poffele
Regards
Porous domain - Volume porosity change ... no effect?? Roland R CFX 9 February 7, 2020 01:56
Chemical Reaction in Porous Domain cibo CFX 7 October 21, 2019 08:55
injection problem Mark New FLUENT 0 August 4, 2013 02:30
Porous domain set-up from single pressure loss value siw CFX 1 December 8, 2011 17:36
Material identification between a flow domain and a porous domain Ervideiro CFX 1 June 1, 2010 10:50
