Radial velocity with a swirling core in laminar pipe flow |
June 25, 2015, 22:55 |
Rep Power: 12 |
Can everybody explain me where that the radial velocity come from in straight pipe flow with a swirling wall in the core of the pipe ? I suppose that it is in relation to boundaries layers ?! Although the radial velocity is negligible compared with the others components, I noted that the radial velocity reach a max peak near the rotating wall and an other near the static wall and I just wondered why ? Thank you |
June 26, 2015, 08:03 |
Rep Power: 144 |
Yes, this sounds like a secondary flow. Look up "secondary flow" on google and you should get some good examples of flows you would not expect.
solving a conduction problem in FLUENT using UDF | Avin2407 | Fluent UDF and Scheme Programming | 1 | March 13, 2015 03:02 |
Laminar pipe flow | John | FLUENT | 6 | December 5, 2014 06:00 |
Boundary condition of velocity and pressure at interface for air water pipe flow | jignesh_thaker2007 | OpenFOAM Running, Solving & CFD | 0 | June 10, 2014 17:42 |
Time averaged velocity in turbulent pipe flow | tsero | FLUENT | 1 | November 2, 2012 04:19 |
WSS and normal velocity gradient for the slanted pipe | wanna88 | FLUENT | 2 | October 1, 2012 23:34 |
