June 23, 2015, 14:46 |
CFX- Monitoring points -error
Hossein
Rep Power: 11 |
Hi everybody,
I need to monitor pressure and total pressure inside of my computational domain during unsteady simulation. so I defined some monitoring points inside the flow domain. However, my unsteady simulation crushed at the beginning. I got this error: +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | Errors were encountered in the CFX Command Language for this run: | | | | Error: Sub-object 'MONITOR LOCATION CONTROL' is not allowed in /- | | FLOW:Flow Analysis 1/OUTPUT CONTROL/MONITOR OBJECTS/MONITOR POINT- | | :BLSS1 | | Error: Sub-object 'POSITION UPDATE FREQUENCY' is not allowed in - | | /FLOW:Flow Analysis 1/OUTPUT CONTROL/MONITOR OBJECTS/MONITOR POIN- | | T:BLSS1 | | Warning: Can't check object /FLOW:Flow Analysis 1/OUTPUT CONTROL- | | /MONITOR OBJECTS/MONITOR POINT:BLSS1/MONITOR LOCATION CONTROL: Ca- | | n't find rule. Skipping object and all children. | | Warning: Can't check object /FLOW:Flow Analysis 1/OUTPUT CONTROL- | | /MONITOR OBJECTS/MONITOR POINT:BLSS1/POSITION UPDATE FREQUENCY: C- | | an't find rule. Skipping object and all children. | | Error: Sub-object 'MONITOR LOCATION CONTROL' is not allowed in /- | | FLOW:Flow Analysis 1/OUTPUT CONTROL/MONITOR OBJECTS/MONITOR POINT- | | :BlPS1 | I appreciate if help me out of this problem. Thanks hhm747 |
June 23, 2015, 14:59 |
Rep Power: 33 |
You seem to have created the setup in a more recent version of ANSYS CFX, and running the case in an older version.
June 23, 2015, 16:48 |
Hossein
Rep Power: 11 |
Yes, I lunched it with old version. It is ok with new version.
cfx 14.5, monitor points |
Problem running perturbUCyl | sen.1986 | OpenFOAM | 17 | June 4, 2019 06:56 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 07:45 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 12:39 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 08:11 |
