Rep Power: 13 ![]() |
Let say the domain reference pressure is 1 atm (atmospheric pressure). May I know the input value of relative pressure if I change the flow from subsonic to supersonic (k-epsilon model)? Is it equals to 0 Pa or pressure of that particular equipment during release?
Rep Power: 144 ![]() ![]() ![]() ![]() |
It depends on the flow configuration, so your question is unanswerable. It sounds like you need to do some reading about compressible flow as your question is probably a standard compressible flow equation.
Also the reference pressure is used to reduce numerical round off errors in the simulation. It tells you nothing about the flow conditions. |
Compressible Flow Pressure Outlet Back Flow | okstatecheme | OpenFOAM Running, Solving & CFD | 1 | March 21, 2018 09:11 |
Inlet and Outlet Pressure condition for Compressible Flow in FLUENT | rsdsaurav | FLUENT | 1 | May 17, 2015 15:19 |
Pressure contours in two compressible phase flow | Hershey | Fluent Multiphase | 1 | June 6, 2014 08:41 |
Compressible, turbulent flow in a pressure tube | Mario | FLUENT | 2 | August 9, 2005 02:47 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
