sunil
Rep Power: 14 ![]() |
Hello everyone,
I am trying to setup RSM to run CFX in cluster in windows 7 system. after adding computing server to the solver manager in RSM, when i run test run(within the RSM) i am getting following error node2(\\10.40.95.102) could not be reached. where node 2 is my compute server to which i am planning to submit job. I think the problem is related to the communication between the systems. license manager is installed on server machine(Windows server 2012 R2). (I have attached respective error message screen shot with this post)Help me to solve this problem. http://s3.postimg.org/jfthx52rn/Capture.jpg Last edited by sunilpatil; June 15, 2015 at 13:28. Reason: image not attached |
Thomas MADELEINE
Rep Power: 11 ![]() |
I am really not an expert with RSM (I have also a lot of problem with). but if we want to help you I suggest you to re post your image with the debug lines.
right click on the console area and select number of line and the debug lines. hope the above help |
sunil
Hello Sir,
here are the debug lines Manager Version 15.0.412.0 [Tuesday, October 15, 2013 12:37 PM] Job Template: C:\Program Files\ANSYS Inc\v150\RSM\Config\xml\GenericJob.xml AllowClientDirectorySharing is set to True Check Manager can see the client directory ... True Manager Project Directory will share Client Directory. Manager can share client directory Job submitted to Immediate queue Client Version 15.0.412.0 [Tuesday, October 15, 2013 12:37 PM] Client Machine: JATP Client Account: CML\administrator Client Directory: C:\Users\Administrator\AppData\Local\Temp\jgboxnv5 .0vb Manager running on JATP.cml.com Manager running as NT AUTHORITY\SYSTEM Manager Project Directory: C:\Users\Administrator\AppData\Local\Temp\jgboxnv5 .0vb node1 (\\10.40.95.101) could not be reached. |
could not reached, rsm |
Some questions about a multi region case run in parallel | zfaraday | OpenFOAM Running, Solving & CFD | 5 | February 23, 2017 10:25 |
fatal overflow error in the FINMES subroutine for CHT run | prashant79_ss | CFX | 5 | September 27, 2014 04:54 |
Cannot run phoenix on linux opensuse 13.1 kde | mabal | Phoenics | 0 | June 15, 2014 06:16 |
[mesh manipulation] Cannot get refineMesh to run in parallel | smschnob | OpenFOAM Meshing & Mesh Conversion | 2 | June 3, 2014 11:20 |
Help-Edit Run in Progress | BalanceChen | CFX | 0 | March 30, 2011 09:23 |
