Pressure problems with inlet variable velocity
Old   June 10, 2015, 20:20
Default Pressure problems with inlet variable velocity
Diego Jaimes
jaimesdiegop is on a distinguished road
Hi everyone, I'm modeling a laminar flow of water through a tube in axisymmetric way with 5°. From a fully developed flow on t=0[s] and I'm decreasing the main inlet velocity every timestep with a constant aceleration but in the first timestep when the inlet velocity is decreasing I got a pressure drop of total pressure that results false.
First I ran one steady state to get my fully developed flow with:
Inlet: Velocity profile (Poiseuille Flow)
Wall: no slip. smooth
outlet: Total pressure
After that I got my initial conditions solution. I tried to run a transient with the steady state as t=0[s] with:
Inlet: Velocity profile - V
wall: no slip. smooth
outlet: Total pressure (the same of the steady state)
with V as a variable V=aceleration(constant)*t
As I have a simulation of incompressible flow, I should have no pressure drop in my tube, as I have on my first steady state, but I get a false pressure drop proportional to my aceleration. I also ran another steady state of my final time step expected, with:
V=a*tf= final velocity
and I have a good result with no pressure drop. I want to obtain the same result with my transient but unfortunately I can't.
If someone knows why I have this problem, how to fix it or what am I doing wrong, please let me know.
Thanks for your help!
jaimesdiegop is offline   Reply With Quote
Old   August 31, 2016, 12:33
Arrow cfd fluent Heat Transfer
Ibrahim
slam is on a distinguished road
Hi All,
I have been started to use Ansys fluent to simulation thermal resistance, overall heat transfer coefficient, and heat loss through cylinder with insulation material of tow layers. Any one has been worked on it pleas help me.
Slam
slam is offline   Reply With Quote
Old   September 1, 2016, 03:31
Jiri
Jiricbeng is on a distinguished road
1) Incompressible does not mean there are no losses, even if you have free slip on walls, you still have losses in the liquid.
2) Try setting static pressure outlet instead of total pressure.
3) How many iterations per time step do you have?
Jiricbeng is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
How to set up the inlet boundary condition for a low pressure case? beastieboys6 FLUENT 3 April 10, 2012 23:46
emag beta feature: charge density charlotte CFX 4 March 22, 2011 10:14
Pressure farfield vs Velocity Inlet BC DarrenC FLUENT 1 September 16, 2009 03:23
Pressure Inlet Velocity prapanj OpenFOAM 11 June 23, 2009 12:15
