FSI problem
Old   June 9, 2015, 13:42
Default FSI problem
Amir Foad Farshchi
amir foad is on a distinguished road
Hi guys,
I am working on a micro pump by coupling structure and CFX.
I want to do transient CFD analysis, but after structural time step finishes, ANSYS says an error: fatal error, can not read mesh deformation data from interface. This happens when the membrane goes up in diaphragm.
I have not this problem in steady-state analysis.
I would appreciate if you help me.
Thanks in advance
amir foad is offline   Reply With Quote
Old   June 12, 2015, 11:43
Matthias Voß
mvoss is on a distinguished road
Check the FEM results.... the solver is telling you " i cannot get the displacement..." because ANSYS crashed in the very last timestep. Often you can check the ANSYS.rst for what has happend in the "crashed, unconverged" last load step to get an idea what probably caused the problem.
mvoss is offline   Reply With Quote
Old   June 15, 2015, 14:33
Amir Foad Farshchi
Dear Mathias,
I checked the .rst file, but still don't understand where the error comes from
Old   June 15, 2015, 16:09
Default FSI problem
Matthias Voß
Did the last ansys loop reach convergence?
Old   June 16, 2015, 08:11
Amir Foad Farshchi
No it doesn't converge at the last step
Old   June 16, 2015, 08:40
Matthias Voß
Did you check where the residual is bad? Activate the NewtonRaphson-option in the Ansys results and re-run the case.
How big was the displacement for this last time step? Did the cfx solver reach converge?
At which point in the simulation did the error occur?
How was the interface convergence?
How did you set the relaxation of the transferred variables?
There are many reasons for the coupling to go wrong.
Old   June 16, 2015, 12:09
Amir Foad Farshchi
I set Raphson-Newton to Full.
at the last step the deformation is 9 microns (the geometry is the circular shell with 750 microns radius.
after 5 Iteration in interface, the simulation stops.
CFX solver didn't even start.
Interface residual is almost constant after 3rd iteration.
I set the convergence to 1E-4 RMS for mesh displacement and 1E-2 for interface variables.
The Initial condition is set to zero for all velocities and relative pressure.
And eventually I got this error in structural : Element 1 has excessive thickness change
By the way, thank you for your help man.
Old   June 16, 2015, 12:56
Amir Foad Farshchi
I forgot, set under-relaxation to 0.75
Thanks Matthias
Old   June 16, 2015, 14:00
Default FSI problem
Matthias Voß
What do you mean by "constant after third iteration"? Did the error rise up in the First Time step? Sounds like the initial deformation/stress is to much. How do you change fluid conditions from initial to working conditions? Can you Post a pic of both CFD And FEM Part?
Old   June 16, 2015, 14:01
Amir Foad Farshchi
residual values neither do go up nor down
actually I reduced the number of steps and the error removed but I got negative volume element instead
Old   June 16, 2015, 14:02
Amir Foad Farshchi
actually I reduced the steps and the error removed but I got negative volume element instead
Old   June 16, 2015, 20:13
FAQ: http://www.cfd-online.com/Wiki/Ansys..._went_wrong.3F
Old   August 9, 2015, 23:27
hallow rocks
unihit4392 is on a distinguished road
I am trying to do FSI simulation of sinusoidal flow in elastic tube. Even i am having same error (excessive change of thickness in element). Did you resolve it?
unihit4392 is offline   Reply With Quote
Old   August 10, 2015, 06:47
Amir Foad Farshchi
you should find an optimum element size to avoid negative volume.
This link may help you: http://www.cfd-online.com/Wiki/Ansys..._went_wrong.3F
Old   August 10, 2015, 08:34
hallow rocks
ok thanks for the info
Simple FSI (fluid structure interaction) Problem kilroy Main CFD Forum 0 January 7, 2015 15:42
Defining contact regions in FSI problem.!!! sreemvlk ANSYS 0 June 12, 2014 01:33
prestrain in FSI problem mina.m STAR-CCM+ 0 October 31, 2013 12:39
divergent of a FSI problem edooo0 FLUENT 0 August 5, 2013 18:54
FSI MODELING PROBLEM (pinball)!!! smn CFX 1 September 16, 2009 01:33
