Developed turbulent boundary layer simulation on flat plate |
June 8, 2015, 06:50 |
Jack B.
Rep Power: 17 |
I'm doing a RANS simulation of a developed turbulent boundary layer on a 3-D flat plate. I've assumed a certain thickness for the BL at the inflow and correspondingly defined the inflow velocity profile. My question is how can I define a pre-calculated shear stress only at x=0 (to simulate a certain shear stress at a given location of developed BL) while the rest of the plate will remain as no-slip wall. Avoiding this will cause a jump in the shear stress near the LE just like in normal BL development. Thanks, Jack |
June 8, 2015, 07:30 |
Rep Power: 144 |
You could make a separate wall boundary for the first element which you define as a slip wall (or a wall with a defined wall shear stress if you prefer). Then the rest of the wall can be a normal wall boundary condition.
June 8, 2015, 12:41 |
Jack B.
Rep Power: 17 |
Hi Glenn,
I've tried your suggestion but it seems that specifying pre-defined shear on the first cell stripe did not helped much... there's still a jump in the shear stresses distribution near the LE and the solution was poorly converged. What do you think? Thanks, Jack |
June 8, 2015, 20:46 |
Rep Power: 144 |
First of all, check your simulation accuracy: Mesh, convergence, time step, etc. Unless they are under control anything could happen.
Assuming they are under control: I would compare the fully developed BL you have generated to one which CFX generates with a simulation. Are they the same? |
Stripes in the boundary layer - Turbulent flat plate tutorials | Jrmy | SU2 | 1 | July 17, 2014 11:48 |
Turbulent Boundary Layer on a Flat Plate | Hoshang Garda | FLUENT | 1 | November 27, 2013 11:24 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Validating OF, turbulent flow over flat plate | Thilo | OpenFOAM Verification & Validation | 0 | July 3, 2012 06:29 |
flat plate boundary layer data | Ekachai Juntasaro | Main CFD Forum | 3 | March 14, 2001 00:18 |
