Interface between a stator-rotor with sudden change in flowpath of the turbine
Old   May 18, 2015, 14:04
Default Interface between a stator-rotor with sudden change in flowpath of the turbine
AGNIMITRA
mitra22 is on a distinguished road
Hi ! Every one.. I have so far successfully carried a good number of single stage and multistage turbine simulations using the stage interface option.
Now I have a problem in which the flow path is not continuous i.e. there is a sudden step in the flow-path hub and shroud radii from stator to rotor domain.There are 10 stator blades and 27 rotor blades.
Usage of stage interface gives a different mass flow rate at the stator outlet and rotor outlet domains (flux is conserved as it should be) but i want to avoid this flux scaling. Mass flow in stator and rotor domains should be equal.
Kindly suggest an option where such sudden changes in area can be handled along with frame change(stationary to rotational domains). I have the flexibility to alter the geometry slightly by displacing the rotor a little downstream.
Thanks in Advance.
mitra22 is offline   Reply With Quote
Old   May 18, 2015, 21:56
Opaque will become famous soon enough
I do not understand your requirement than the mass flow through the stator must be equal to the mass flow through the rotor.
That can only happens if your model is the full stator with the full rotor, or the pitch of both the stator and the rotor is the same.
If you are modeling a reduced number of passages on both components, the mass flow through each component must be different; otherwise, you will violate conservation of mass.
Opaque is offline   Reply With Quote
Old   May 19, 2015, 05:07
Thomas MADELEINE
Thomas MADELEINE is on a distinguished road
We already discuss on subjects like that on this thread. I agree with Opaque, you should always keep the massflow constant on your physical domain, not always on your mathematical one...
http://www.cfd-online.com/Forums/cfx...t-details.html
Thomas MADELEINE is offline   Reply With Quote
interface, step in flow path, sudden change in geometry
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Problem with interface in a wind turbine simulation be_inspired FLUENT 2 March 8, 2011 00:46
Interface w. Pitch Change: Thcfd CFX 0 December 22, 2010 04:50
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
how to change blade leading angle of axial turbine dia aisa CFX 0 June 2, 2008 03:45
