May 13, 2015, 18:32 |
Null radial mean velocity
Rep Power: 12 |
Does anyone tell me mathematically how can I see that the radial mean velocity is absolutely null on a section in a pipe ? Thank you |
May 13, 2015, 18:48 |
Rep Power: 144 |
Define a isosurface at a small positive radial velocity and another at a small negative radial velocity. In between the isosurfaces is the region of almost zero radial velocity.
LES and TKE calculations | MST | Main CFD Forum | 3 | May 30, 2016 06:26 |
UDF : velocity, k and epsilon (radial profile) | cdiako | Fluent UDF and Scheme Programming | 23 | July 30, 2013 08:29 |
Axial, Radial, Tangental velocity in FLUENT post | Barri | FLUENT | 2 | March 6, 2008 20:29 |
Radial Position and Axial Velocity Graph | Sal | FLUENT | 2 | August 1, 2007 09:29 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
