Convergence issue in CHT simulation
Old   May 8, 2015, 14:33
Lightbulb Convergence issue in CHT simulation
Deepak
funDevil is on a distinguished road
Hi All,
For my first CFD simulation, I was required a simulate a CHT system for NATURAL CONVECTION. The system has 2 components - plastic tube (almost U-shaped)and a heat sink. The heat sink snugly fits into the open face (along the length), such that the both together form a hollow tube with fins of the heat-sink in the air passage. The was to study the temperature distribution over the system at steady-stage.
When I start the simulation, for some reason all the residuals don't seem to decrease (see attachment). I have attached the images of geometry, mesh, and the residuals plot. I am not sure where I am going wrong. I need help!
Deepak
funDevil is offline   Reply With Quote
Old   May 8, 2015, 21:56
alg
Alan
alg is on a distinguished road
I might not be the best person to give advice on how to converge a CHT problem (see my other post), but you could try refining your mesh in the fluid domain (and adding more inflation layers). I'm assuming that your opening boundary conditions are asserting a pressure drop along the channel (and hence a flow)?
alg is offline   Reply With Quote
Old   May 8, 2015, 22:47
Deepak
Alg,
Its a natural convection problem. The ends of the tube are open to atmospheric pressure.
Like you suggested, I increased the number of inflation layers (to 5), and it did not help. Thanks for the inputs.
Old   May 8, 2015, 23:11
alg
Alan
Ok, no worries.
How are your opening boundary conditions set then? and which way does your gravity vector point? I've run a similar simulation recently but modelled a fuild domain 'around' the channel, linking the inlet and outlet, with openings on the outer surfaces of this larger domain. This avoided the situation where you have a pressure set at each end of the channel, which will dictate the mean flow. There may be an easier way to do this though...
Old   May 9, 2015, 07:48
Before we dive into details on this simulation - have you read the FAQ on this issue? http://www.cfd-online.com/Wiki/Ansys...gence_criteria
cfx, conjugate heat transfer, fins, heatsink, natural convection
Wind Tunnel Flow Simulation Mass Flow BC Issue ledelman SU2 4 August 3, 2014 19:38
Convergence issue on Solar chimney simulation Mani.juve FLUENT 0 November 19, 2012 18:00
DPM simulation convergence problem gemini FLUENT 2 May 22, 2012 02:41
[CFX] Simulation of Flow Separation in a rectangular diffuser - Convergence Problem anon_b CFX 11 May 6, 2012 21:16
Convergence problem with axial pump simulation! cnchilavert CFX 2 October 5, 2011 05:23
