towing force of self propulsion test
Old   April 28, 2015, 10:04
Default towing force of self propulsion test
mnfbhn
mehdinakisa1358 is on a distinguished road
Hi Dear All,
I'm doing self propulsion test using CFX simulation. How can i calculate the towing force on ship model in Cfx? when propeller rpm changed how measure the towing force changing?
mehdinakisa1358 is offline   Reply With Quote
Old   April 28, 2015, 20:15
You can measure the force on a body using CEL expressions.
You change the rpm and then measure the force - simple.
Old   April 28, 2015, 23:59
mnfbhn
yes, but i got more force of hull body after increasing the rpm. I need to measure the towing force not Resistance due to ship hull movement.
many thanks
Old   April 29, 2015, 01:19
Can you post an image of what you are modelling, what you have taken the force from and what you expect the force to be.
Old   April 29, 2015, 10:23
mnfbhn
pls, imagine, the propeller behind the ship.
rpm is 200rpm. we have the thrust and ship hull resistance. I want to know how can determine the towing force in compare of propulsion test which is get the towing force towed by carriage.
Thanks
Old   April 29, 2015, 18:17
At a particular speed, if you have the hull resistance force and the propeller thrust force the towing force must be the force required to get these forces to balance.
Old   April 29, 2015, 23:59
mnfbhn
Yes, very good. many thanks and appreciated.
Mehdi
Old   January 24, 2021, 22:03
Default Self-propulsion
jaym
Ngaru is on a distinguished road
I am carrying out self-propulsion for ship model with a rotating propeller using OpenFOAM.
My propeller rotation motions are modelled using AMI.
My problem is that sometimes my propeller behind the hull is rotating however when I use fine mesh my propeller fails to rotate and the case appears like MRF.
I have tried different clearance between the propeller hub and ship bulb but I have not yielded very promising results.
If there is some with AMI knowledge kindly help me.
Best regards
Ngaru
Ngaru is offline   Reply With Quote
Old   January 25, 2021, 01:15
Posting your question on the OpenFOAM forum would be a good start. This is the CFX forum.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 12:12
Force can not converge colopolo CFX 13 October 4, 2011 23:03
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
