Turning off equations during solution in CFX, like fluent.
Old   April 26, 2015, 09:25
Default Turning off equations during solution in CFX, like fluent.
Adil Syyed
adilsyyed is on a distinguished road
In fluent, we can turn off an equation (say energy equation) at the start of the solution. After some iterations, we stop the solver and turn on the energy equation again.
This technique is very useful when initially the solution tends to diverge.
Is it possible to do this in ANSYS CFX?
adilsyyed is offline   Reply With Quote
Old   April 26, 2015, 18:03
Kushal J
KushalJ is on a distinguished road
I think this should be doable through expert parameters in CFX. search for the expert parameters in ANSYS documentation or look in CFX-pre, Insert -> Solver -> Expert Parameter.
KushalJ is offline   Reply With Quote
Old   April 26, 2015, 18:38
Adil Syyed
Seems like it should be there. I will thoroughly consult documentation and CFX-Pre for expert parameters. If there is any problem, I will come back here and post it.
Thank you Sir.
Old   April 27, 2015, 04:57
Thomas MADELEINE
Thomas MADELEINE is on a distinguished road
to select which equation you want to activate or deactivate :
go to expert parameter -> last tab "model override" -> and then select the equation you want to modify (by default it is on solving of course)
for the stability I would rather use an under relaxation parameter (in the expert parameter too) or play with the order of the calculation like something with the first order and no turbulence as initialization for example.
Thomas MADELEINE is offline   Reply With Quote
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Fluent exceeding Solution Limits on faces bawfuls FLUENT 3 July 10, 2012 17:34
High Resolution (CFX) vs 2nd Order Upwind (Fluent) gravis ANSYS 3 March 24, 2011 03:43
Wall function formulation in CFX and Fluent gravis ANSYS 0 May 4, 2010 12:03
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 07:19
