Export mesh from CFX
Old   April 24, 2015, 06:00
Default Export mesh from CFX
Jiri
Jiricbeng is on a distinguished road
Is there any way to obtain the mesh from CFX (pre or post - .cfx or .res) ? I would like to receive the deformed mesh of the fluid domain due to FSI. Any suggestions appreciated .
Jiricbeng is offline   Reply With Quote
Old   April 27, 2015, 03:23
Lance
Lance is on a distinguished road
I use ICEM for that.
File -> import mesh -> from CFX.
Lance is offline   Reply With Quote
Old   April 27, 2015, 12:00
Edmund Singer P.E.
singer1812 is on a distinguished road
I used ICEM for this also, but it used to be that you had to pass the results into CFXPRE, write out a def file, then read that into ICEM, in order to get the deformed mesh into ICEM. If you didnt do this, you get the original mesh in ICEM.
I last did this in V13 or V14. I am not sure they have updated ICEM to allow direct import of this type.
singer1812 is offline   Reply With Quote
Old   April 28, 2015, 03:27
Lance
In v16 you get an warning:
-- WARNING -- This results file contains multiple meshes. The latest mesh will be loaded, which will be the deformed mesh for a case that includes Mesh Deformation. If the original undeformed mesh is required, you should load the case file (.cfx) or the CFX-Solver input file (.def) instead.
So it seems that they have updated ICEM to account for the deformed mesh.
export comsol mesh into ansys or cfx amazdeh ANSYS Meshing & Geometry 1 June 9, 2017 10:18
[ICEM] How to export Icem mesh to Cfx? darazsbence ANSYS Meshing & Geometry 11 February 23, 2013 15:09
[ICEM] Problem with export mesh icem to CFX TallesC ANSYS Meshing & Geometry 6 February 6, 2013 10:56
Export 2D mesh from ICEM to Fluent BuilttoSpill ANSYS Meshing & Geometry 4 August 28, 2010 09:16
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
