Opening boundary condition for multiphase analysis in CFX |
April 23, 2015, 00:09 |
sluzzer
Rep Power: 12 |
A rotating cylindrical tank initially filled with air, in which oil is entering from one side (inlet). When the oil fills the rotating tanks, the air enters or leaves from another side (say a circular opening), depends on the pressure inside due to the rotation and oil inflow. When the oil fills the tank, then the further oil addition should flow out from the same same circular opening.
So the condition for Circular opening is: 1. air should come in or go out. 2. oil should only go out. How to set up this boundary condition for the circular opening? Is the 'opening boundary' with volume fraction for both oil and air is 0.5, suitable? what is the value of 0.5 signifies here ? (i understood the value of 0 and 1 for initial condition) Also, in Opening boundary, the inflow can happen only due to re circulation or will it assume there is fluid addition at that boundary just like inlet. Please help. Thanks |
April 23, 2015, 06:59 |
Rep Power: 144 |
VF=0.5 means half the control volume is air, half is oil.
Before you implement this unusual boundary condition - can you explain how it comes about physically? Is there some device on the boundary which makes it behave as you describe? I do not understand your other questions. An opening either flow entering the domain (in which case it is assigned the volume fraction you define), or leaving the domain and no volume fraction need be defined as the fluid leaves the domain. |
April 23, 2015, 11:32 |
#3 | |
Rep Power: 33 |
From the documentation
Hope the above helps, |
May 15, 2015, 10:49 |
sluzzer
Rep Power: 12 |
Thanks ghorrocks.. I understood...
Opaque, Degassing boundary is applicable for dispersed fluid not for continuous fluid. Sorry for the very late reply :-P |
multiphase boundary wall |
Time dependant pressure boundary condition | yosuke1984 | OpenFOAM Verification & Validation | 3 | May 6, 2015 07:16 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
pressure wall boundary condition in CFX | murx | CFX | 4 | October 9, 2012 07:50 |
Boundary Condition in CFX | ssbear | CFX | 5 | February 7, 2011 02:10 |
Boundary Condition in CFX | ssbear | ANSYS | 1 | February 1, 2011 21:43 |
