tilting disc in aortic valve
Old   April 22, 2015, 04:39
Default tilting disc in aortic valve
aidaaida is on a distinguished road
Hi
I am modeling a tilting disc placed in aortic valve, it is a 2D project, when blood comes to aortic valve, it cause moving in tiling disc (because of the pressure difference).and tilting disc opens, after that when pressure in heart becomes more than in valve, the valve closes.
I heard that it solved by FSI, Im beginner and I just created a geometry.
can I mesh in ICEM CFD?
I read this paper, can I use it for my project?
http://www.edr.no/blogg/ansys_blogge...cfx_re_meshing
can anyone help me? I would really appreciate it
aidaaida is offline   Reply With Quote
Old   April 22, 2015, 07:30
Lance
Lance is on a distinguished road
Have you done the ball check valve tutorial (number 22)? Sounds like it is about the same as what you are trying to do.
You can mesh in whatever software you like, ICEM, workbench mesher, ANSA, etc...
Lance is offline   Reply With Quote
Old   April 22, 2015, 10:43
thanks for your reply.
I think it's different from my problem, the tilting disc is moving, and I want to analysis this movement by the time.but in this tutorial, the valve isn't moving.can you suggest me another tutorial about my problem?
Old   April 22, 2015, 10:50
Lance
Read the tutorial again. It is both rigid body simulation and mesh deformation.
Building an aortic valve using Immersed Solid method TheForumLord CFX 3 June 12, 2014 03:54
Modelling an initially closed valve which a fluid opens siw CFX 1 April 26, 2014 07:32
Gate valve flow simulations... nikesh FloEFD, FloWorks & FloTHERM 5 January 28, 2014 02:31
Rotating Disc in a Volume of Air alcesalces Siemens 0 August 24, 2009 14:59
CFD of tilting disk check valve Greg Anderson Main CFD Forum 1 July 13, 1999 18:07
