Controlling Total Pressure using Conditional Loops |
April 10, 2015, 06:41 |
Engineer
Rep Power: 13 |
Hallo,
I am trying to simulate a model with massflow inlet (2 inlets) and a single static pressure outlet. Saying that I need to have an absolute total pressure at my inlet of 1.0 bar. I have achieved it by monitoring the total pressure at inlet and then decreasing my relative static pressure at outlet. Instead of doing it manually, is it possible to write a CEL using so that it monitors the total pressure at inlet and thereby reduces the static pressure at outlet by an user-defined factor say for every 50 Iterations. Any help would be much appreciated. |
April 10, 2015, 06:47 |
Mr CFD
Rep Power: 15 |
Yes I think you can do what you want using simple CEL expressions.
There is an example in the CFX reference guide which uses variable inlet Temperature (and not mass flow rate). In your case replace temperature with mass flow rate since the theory is the same. In the reference guide it's located in: 14.3.2. Example: Feedback to Control Inlet Temperature |
April 10, 2015, 06:58 |
Engineer
Rep Power: 13 |
Hallo RicochetJ
Thanks for the info. I have gone through the example, but the value of temperature is a step function which fluctuates between two values. In my case, to have a desired total pressure at inlet, i do not have a limit (say lower) limit for my static pressure. I do not know before hand for what value of static pressure would i get a absolute total pressure of 1 bar at inlet. Is it possible to write a If loop for example, if(massFlowAve(Total Pressure)@Inlet ==1.0[bar],DoNotChangeStaticPressure,ChangemyStaticPressureb ya Factor) |
April 10, 2015, 09:01 |
Peter
Rep Power: 15 |
Maybe you can try:
statOut=areaAve(Pressure)@Outlet staticPressOut=if(massFlowAve(Total Pressure)@Inlet <1.0[bar],statOut,factor1*statOut) where factor1<1 This works only if your coming from a high pressure. When you want to regulate from both sides (as you intended with ==1bar) you have to use sth like: staticPressOut=if(massFlowAve(Total Pressure)@Inlet ==1.0[bar],statOut,changepressure) changePressure=if(massFlowAve(Total Pressure)@Inlet >1.0[bar], factor1*statOut, factor2*statOut) where factor1<1 and factor2>1 But in this case it is probably getting unstable since you never reach exactly 1bar. (Not tested, just a guess) |
April 10, 2015, 09:38 |
Mr CFD
Rep Power: 15 |
I just realised something...
If you want 1.0 bar at the outlet, and you don't know what to have on the inlet then just simply do this: Set the outlet as a pressure outlet with a pressure of -1.0 bar Set the inlets as openings with a pressure of 0 bar. The solver will automatically determine the mass flow rates and pressures needed at the opening to maintain continuity. |
Total pressure and mass flow boundary condition at inlet | bscphil | OpenFOAM Pre-Processing | 3 | July 9, 2017 15:39 |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 11:08 |
Total pressure BC with simple foam | duri | OpenFOAM Running, Solving & CFD | 1 | March 20, 2012 09:05 |
rotating frame of reference and total pressure | viking | ANSYS | 1 | November 24, 2010 00:25 |
total pressure in CFX | Atit Koonsrisuk | CFX | 0 | January 1, 2005 06:46 |
