April 10, 2015, 06:13 |
Mass flux [kg /m^2 /s] as a monitor point
Mr CFD
Rep Power: 15 |
Hi, I have a pressure outlet boundary condition, and some air is passing through it.
I have a target to reach for CFD validation purposes, which is 40 kg /m^2 /s How do I actually monitor mass flux through my surface in CFX? If I monitor the expression massFlow@outlet it gives me kg /s and not my needed kg /m^2 /s There isn't a mass flux variable either. Is there a simple solution to this please? |
April 10, 2015, 09:20 |
Rep Power: 33 |
You can monitor massFlow@Outlet / area@Outlet, that is the mass flux.
April 10, 2015, 09:35 |
Mr CFD
Rep Power: 15 |
Off course it is! Thank you!
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
mass flux correction at outflow boundaries | Subhra Datta | Main CFD Forum | 2 | November 24, 2003 14:11 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
total mass flux correction for compressible fluid? | Francesco Di Maio | Main CFD Forum | 0 | August 21, 2000 05:23 |
