Pulsatile Inlet & Opening Outlet
Old   April 8, 2015, 04:19
Question Pulsatile Inlet & Opening Outlet
Guan
zxcvbnm2010 is on a distinguished road
Hi everyone
I have a trouble. I run model as a straight tube. When I set the pulsatile inlet and constant pressure outlet, it will be overflow.
So, I change the constant pressure outlet to opening outlet. But the results are really strange. The flow is reverse. How could I get the normal flow direction(In→Out) at any timestep?
Thanks a lot for your help and time.
Best Regards
zxcvbnm2010 is offline   Reply With Quote
Old   April 8, 2015, 06:52
In the post processor draw a contour of the normal component of velocity on the boundary. Then use it to draw a contour of velocity =0. All the flow in one direction will be one colour, all the flow in the opposite direction will be another colour.
Old   April 8, 2015, 09:16
Guan
Sorry, you misunderstood what I meant. My problem is how to solve the flow direction correct (In→Out)?
At some timestep result, the flow direction is wrong (Out→In).
Thank you.
Old   April 8, 2015, 18:54
If you mean the backflow is wrong, so how to stop the back flow? Well, the backflow is a result of the conditions you apply. If you are applying a pulsing flow then it sounds like backflow is inevitable.
I think you need to go back to basics on this simulation. What are you actually trying to model? What do you know about the flow?
Old   April 8, 2015, 23:13
Guan
Sorry, I know backflow is inevitable. But as you could see the picture, my inlet is change into outlet.
I want to try a pulsatile flow in a stright tube. I setup inlet boundary conditions as a function of timestep. Inlet is always be inlet, but this picture result inlet flow direction is oppsite. I need to get inlet flow direction is a fixed direction, how could I solve this problem.
Thank you in advance.
Old   April 9, 2015, 03:01
Guan
I think I found the problem. Is my expression too complex?
Plot it.
I really need this wave of inlet velocity. If my expression is incorrect, please help me.
Many thanks.
Old   April 9, 2015, 07:08
Can you post your CCL?
Old   April 9, 2015, 09:40
Frank Weise
FrankW is on a distinguished road
Why do you use Current Time Step (ctstep) instead of time (t)?
FrankW is offline   Reply With Quote
Old   April 9, 2015, 10:31
Guan
I misunderstand ctstep mean...
Thank you all. I use time(t) instead of Current Time Step (ctstep).
And it does work. The flow direction is correct.
Really pretty thanks!!!
elbow: boundary conditions for inlet and outlet cgoe OpenFOAM Running, Solving & CFD 1 November 8, 2014 14:26
Outlet Backflow problem in simulating pulsatile flow a.sarami CFX 0 August 31, 2013 10:41
boundary condition for coupled inlet and outlet xxxx OpenFOAM Pre-Processing 2 August 13, 2013 16:51
Unsteady pressure differential between inlet and outlet of the pipe for single phase joshi20h FLUENT 0 September 26, 2012 13:41
total pressure boundary problem ==> flow from outlet to inlet!! mrshb4 OpenFOAM 0 November 20, 2010 13:41
