Node-centered and cell-centered finite-volume discretizations |
April 8, 2015, 01:01 |
Rep Power: 12 |
Can you confirm me that for an identical structured mesh, is the number of volum control the same with cell-centered finite volume method and node-centered volume method if we don't consider boundaries ?
What is the difference exactly with these two approaches ? Thank you for your help |
April 8, 2015, 06:50 |
Rep Power: 144 |
No, the number of volumes will not be equal.
The difference is whether the control volume is centred on the element or the node. This is covered in most basic CFD textbooks. They describe it better than I can on a forum, so wander down to your local library. |
April 8, 2015, 10:28 |
Rep Power: 12 |
Ok thank you.
Can you just tell me why did you say that the number of volumes will not equal if we don't consider boundaries because I read exactly the opposite. The number of volume will be different because of boundaries. |
April 8, 2015, 18:58 |
Rep Power: 144 |
I did not see the comment about the boundary. For each internal node in both cases there will be one control volume. So that means the internal control volumes will be the same. But there will be differences in the boundaries.
gradient calculation of cell centered finite volume method | zhengjg | Main CFD Forum | 10 | November 12, 2012 00:13 |
Cell vertex FV vs Cell centered FV | peter.zhao | Main CFD Forum | 1 | September 15, 2004 10:26 |
node based or cell centered Ts values | acboge | FLUENT | 0 | February 6, 2004 07:41 |
Node centered and cell centered. | Confused. | Main CFD Forum | 9 | August 29, 2003 14:54 |
Cell vertex V.S Cell centered | peter.zhao | Main CFD Forum | 3 | November 13, 2002 05:47 |
