Compression stoke is giving higher pressure than calculated
Old   April 20, 2015, 23:51
Nick
nickjuana is on a distinguished road
The only way is to do hexa mesh..? The geometry is some what complex
nickjuana is offline   Reply With Quote
Old   April 21, 2015, 00:21
The mesh motion will run a lot better and more reliably if the bit which squashes up is a hex mesh (or a wedge mesh, anything which is an extrusion in the direction of squashing).
So in this case I would put the features at the bottom of your image in one mesh region which can be a tet mesh with inflation, but then transition to an extruded mesh for the cylindrical potion. Join the two with an interface with a 1:1 connection. Then make the tet mesh region either stationary or move with a velocity everywhere so this section just translates, and put the mesh motion on the cylindrical region so only this region squashes up.
I have done this many times when I used to do IC engine simulations in CFX so I can assure you it works well. I had features on both the piston and the cylinder head with a cylindrical region connecting them, and all the mesh squashing was done in the cylindrical section.
Old   April 22, 2015, 09:28
Nick
Are you telling me that put outer surface as tetra and inner region as hexa..?
Old   April 22, 2015, 22:34
No. Here's a dodgy drawing of what I mean on your geometry:
The cylindrical bit is an extruded mesh (probably hex, but could be wedges). The complex bit is a tet/inflation layer mesh.
Old   April 23, 2015, 01:18
Nick
Is it possible to do in ICEM CFD ..? or only with workbench
Thing is that I want hexa mesh internally for bottom portion that is the piston profile then only I will be able to compress.
Old   April 23, 2015, 06:55
This is easy to do in ICEM. ICEM is very flexible.
It is possible to do it in Workbench but not as easily.
You can mesh the piston profile any way you like. Just use an extruded mesh (hex or wedge) for the section which you squash and stretch to do the piston motion.
Old   May 3, 2015, 13:54
Nick
I tried to revolve mesh by modelling only 60 degree section. I tried to define periodicity. I enabled mesh and tried to periodic, after periodic for a particular vertice mesh disappears. One particular periodic vertices is making mesh disappear
Old   May 3, 2015, 20:11
I do not understand you question. Please post an image of what you are seeing.
Old   May 4, 2015, 01:21
Nick
This is geometry I am trying to revolve and I am trying to define periodicity with mesh enabled.
After clicking next vertices, the mesh is not generating. There are two such vertices creating problem. Which are preventing the mesh. what to do..?
Old   May 4, 2015, 01:33
This is an ICEM problem, not CFX. Try the geometry and meshing forum.
But I can see your blocking approach is not good. You want your mesh to match up across the periodic boundary so you should use a blocking which links across the boundaries. It is also much more complex than it needs to be from what I can see. Can you simplify it and use less blocks?
Old   May 4, 2015, 03:05
Nick
I used Y grid at right side because it is complex geometry. It is some what complex profile so thats why I divided into many blocks.
Old   May 4, 2015, 07:44
Sure, but as you are using periodic boundaries this creates an additional constraint on the way you block it so the mesh matches on both sides of the interface. You will need to think about that as well as the blocking to fit into the geometry.
Alternately you could forget about matching the mesh over the periodic boundary and just connect it with a GGI.
Old   May 5, 2015, 13:44
Nick
Can you please tell about GGI...?
Because I am unable to find solution to revolve this complex geometry
Old   May 6, 2015, 00:13
It is in the interface tab. You should have a choice of 1:1 or GGI.
Old   May 6, 2015, 23:33
Nick
Geometry
Problem area
some mesh are coming inside and after solving few iteration its saying mesh is folded or invalid
Old   May 7, 2015, 03:25
You have not implemented the recommendation I told you in my post #44. That is the way to fix this.
You also need to be sure your mesh is correct with the blocks connecting properly (Ie contiguous)
Old   May 7, 2015, 03:48
Nick
I tried my level best to block this complex geometry but what you told in post44, I dont know how to do that because piston with profile on the land part should have Hexa mesh. How do I put hexa interior and tetra exterior in the piston part...?
Old   May 7, 2015, 19:17
You are always going to have problems moving this mesh unless you implement my suggestion. So you need to do some meshing tutorials so you can see how to hex mesh these geometries and split it into multiple mesh blocks.
Old   May 8, 2015, 01:23
Nick
Brother I am ready to do in your way but I have no idea how to do that. Is it like put only tetra in piston and hexa in cylinder....?
I tried putting tetra in piston alone but some mesh are coming out of the piston. what to do in that case ..?
Old   May 8, 2015, 04:10
Meshing this sort of object is easy in ICEM. You can easily do one section as a inflation/tet mesh and the other as a swept mesh. But it is a total pain in Workbench mesher. I am sure it is possible but it always causes me grief when I try to do something like this.
cfx 14.5, engine simulation, pressure boundary
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
UDF to define or adjust pressure??? engahmed FLUENT 0 July 6, 2010 18:19
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
