Temperature increment at wall in compressible flow |
April 1, 2015, 10:11 |
Yogini Patel
Rep Power: 16 |
I am simulating 3D steam turbine stator in cfx using multiphase-droplet condensation model. I have a problem regarding to temperature field. In simulation, the flow temperature on the blade wall increases (reached to 1600 K). I have chosen no slip adiabatic BC for walls. I included viscous work term in heat transfer model option. Can anyone suggest what is the reason of temperature increment at walls ? Thank you in advance. BR, Yogini Last edited by Yogini; April 2, 2015 at 05:29. |
April 1, 2015, 18:52 |
Rep Power: 144 |
A vague question, so I refer you to the FAQ on accuracy: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Here's another FAQ on how to ask a better question: http://www.cfd-online.com/Wiki/Ansys...ible_answer.3F |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 01:04 |
Temperature at a velocity/mass flow outlet | saisanthoshm88 | CFX | 1 | July 8, 2014 19:35 |
Is wall ajacent temperature equal to conservative temperature of the wall? | shenying0710 | CFX | 8 | January 4, 2013 05:03 |
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade | Karkoura | CFX | 0 | March 10, 2011 16:35 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
