April 1, 2015, 03:44 |
CFX Solver Run
Andreas
Rep Power: 12 |
Hello again,
i have a question about the cfx solver termination process. My transient run finished after 2200 iterations and about 17 hours of calculating. The solver stopped with: --> Final synchronization point reached by all partitions. Normally that should not the end of my output-file and therefore no results-file is written. Also i have a "running" symbol displayed in the lower left corner of the cfx solver. I waited for over an hour and nothing happened. Anyone of you had the same problem and can help me? Do i just have to wait? I cannot see a big utilization in task manager, so i dont know if my pc is doing anything for processing. To rename the last *.trn File in a *.res File will bring me a results file, but is this the same as the written results file? Thanks in advance. Flashi |
April 1, 2015, 04:49 |
*.trn file is same as *.res file
Jinwhan Ryuk
Rep Power: 13 |
You don't have to rename *.trn file to *.res. you can just call *.trn in CFX post. Each *.trn file is the same as result file as far as I know unless you set any variable selection at the pre-processor. |
ansys cfx solver exit with return code 1!!!!! | mhabibnia | CFX | 7 | August 19, 2013 04:53 |
CFX solver error | kh_thakor | CFX | 3 | January 11, 2011 17:39 |
CFX SOLVER error !!! | mehrdadeng | CFX | 3 | November 23, 2009 17:42 |
CFX Solver to run 10 files sequentially | Raj | CFX | 8 | October 29, 2008 23:20 |
How to batch run CFX 11 solver on Win XP | James | CFX | 8 | July 10, 2008 12:57 |
