Upwind scheme - convergence problem
Old   March 31, 2015, 23:47
Default Upwind scheme - convergence problem
MissCFD is on a distinguished road
I simulate a passage of stator and a passage of rotor for a hydraulic turbine so I use water. I use a mass flow rate condition for inlet and pressure condition for outlet.
I don't understand why when I use an upwind advection scheme I have a wall which take place in outlet and my calculation differ, crash. This doesn't happen when I use a high resolution or blend factor = 1 for advection scheme.
With an upwind advection scheme, I introduce numerical diffusion so my calculation should converge more easily, isn't it ?
What can I do to avoid that a wall which take place in outlet of my domain ? Reduce the time scale ?
Thank you for your help
MissCFD is offline   Reply With Quote
Old   April 1, 2015, 05:23
Thomas MADELEINE
Thomas MADELEINE is on a distinguished road
For what I understood of the advection scheme :
upwind => blend factor of 0 => first order
HR => blend factor vary between 0.5 and 1 (normally close to 0.9) => relaxation term between first order and second order
blend factor of 1 => second order
The equations will be modeled at each integration by a first/second order function.
first order functions are easier to calculate and converge faster but they are less precise and can't bend so much.
So if you have big gradient the first order will be unable to converge and your simulation will crash.
solution :
stay at an order bigger than 1 (maybe 1.5 => blend factor at 0.5) or refine your mesh.
If I said something wrong please correct me, it is what I understood but I am not 100% sure i get it all.
Thomas MADELEINE is offline   Reply With Quote
Convergence problem in Fluent for quenching process kaeran FLUENT 4 December 1, 2014 03:14
Accuracy problem of HO schemes on unstructured mesh, HO scheme gives 1st order result gemini Main CFD Forum 12 December 27, 2011 22:01
Force can not converge colopolo CFX 13 October 4, 2011 23:03
convergence problem limseokmin FLUENT 3 November 14, 2004 13:43
Help!explicit multistage scheme with upwind scheme D .T. Main CFD Forum 1 June 4, 2003 04:42
