March 30, 2015, 07:54 |
The mass flow rate changes TOO much!
Rep Power: 14 |
I'm trying to simulate a rotor/stator flow. I used the "stage" frame change option and the "High Resolution" Advection Scheme option. The simulation ran fine with 1E-8 RMS residuals and 1E-6 MAX Residuals, but there's something that looks really strange to me: moving from the rotor to the stator the flow rate changes a lot (from 3000 kg/s to 3093 kg/s). Obviously the stator is set to "stationary", while the rotor is "rotating" with a given angular velocity. Do you have any explanation about this behaviour? Thanks so much! |
March 30, 2015, 08:42 |
Rep Power: 33 |
Has the imbalance for the P-Mass equation (continuity equation) converged as well ? What is the mass imbalance reported in the output file, and in the Solver Manager ? Is it consistent with the values you see in CFD-Post ?
March 30, 2015, 09:15 |
#3 | |
Rep Power: 14 |
The P mass converged at 1E-8 RMS and 2.8E-6 MAX In the output file I read: Domain Interface TR_TM Side 2 = -3.0114E+3 (inlet of the Rotor) and Domain Interface TM_RA Side 2 = -3.0338E+3 (inlet of the stator) What do you mean with "mass imbalance reported in the Solver Manager"? The output file collects all the infos reported in the Solver Manager during the calc process, doesn't it? (or maybe I've misunderstood your question) Thanks again |
March 30, 2015, 09:51 |
Rep Power: 33 |
We are talking about .7% mass imbalance here.
In the SolverManager, create a new Monitor Plot, select IMBALANCE, and plot the P-Mass equation. Is the imbalance still converging ? , i.e. it can be reduced further if given more iterations or it has long converged and remained fixed for many iterations. If you increase the time step once converged this far, does the imbalance change. |
March 30, 2015, 10:12 |
#5 | |
Rep Power: 14 |
In Solver Manager I've created a New Monitor, I've choosen "Plot Monitor" and then "Imbalance". Then I've selected P Mass Imbalance (%) Equation" for the Rotor Domain. The graph has converged to 0 (8.8E-8 to be sharp). I've repeated the same procedure with the P-mass Imbalance Equation for the stator domain and obtained the same thing... Yes, it's true, it's a matter of .7%. The strange thing is that with other simulations (in which convergence was just 1E-5 RMS) i didn't see these imbalances. |
CFX turbo - Mass flow rate | Vashishth Patel | CFX | 7 | April 3, 2014 20:33 |
Mass Flow rate in spray water modeling | Behnam Ghadimi | FLUENT | 0 | June 8, 2013 16:05 |
Mass Flow rate in spray water modeling | Behnam Ghadimi | Main CFD Forum | 0 | June 8, 2013 15:48 |
negative global mass flow rate | Gimli | FLUENT | 0 | April 21, 2006 07:17 |
mass flow rate error | Masood | FLUENT | 0 | May 22, 2005 00:32 |
