March 27, 2015, 16:12 |
Tcl code for view position
Rep Power: 17 |
Dear all,
I am not a frequent CFX/CFD-Post user, but need to do some post-processing with CFD-Post at this stage. I was wondering whether someone could explain how to / whether it is possible to set up 'camera views' via Tcl in order to allow me to produce a series of identical results plots for a series of simulations with slightly perturbed geometries i.e. i need to be able to set up exactly the same view to output results to compare slight changes in my geometry. This can be done in Fluent using the TUI using save/restore-view, but i had a go in CFD-Post without much luck. I do not need something complex, just to be able to cycle through my case files and produce the same plots for each of them. many thanks and best wishes in advance regards jonathan ps i hope this is the correct forum for CFD-post, otherwise hoperfully one of the mods will move this post |
March 28, 2015, 05:00 |
Rep Power: 144 |
Yes, you have the correct forum and there is no need for this post to be approved.
Camera views can be set up many ways: * The easiest is by state files. This saves the state of CFD-Post, and then you can load a different results file and apply this state to it. * An alternative is using a session file. This is similar to Fluent's TUI, sort of. Record a session file to do the post processing you want to do and open it in a text file editor and change the results file or add looping or whatever * CFD-Post can also be driven by CCL but you would have to be keen to use this approach. |
March 29, 2015, 07:55 |
thanks
#3 | ||||
Rep Power: 17 |
Dear Glenn,
Thanks very much for the reply Quote:
A further issue is that, if i need to come back and repeat the export with fine tuned results, i cannot recreate the view exactly as it was previously. Quote:
So: is it possible to set up the camera views in the state file or using Tcl in the command editor. I didnt see this in the UG so far ... Quote:
PS good luck for the CWC2015 final - if you are watching EDIT: OK, i realise i am probably mixing up Tcl and CCL - i guess what i am actually after is a set of CCL expressions to set up camera views ... |
March 29, 2015, 08:10 |
Rep Power: 144 |
If your post processing has various graphics and various views then consider a report. Then you can set them all up and easily change the results file to reproduce them all.
The easiest way to find out what a session file can do is to record a session file and do some stuff like move the view around, add a graphics item, change to a new result time step and see what the session file generated looks like. No, I am not watching the cricket but as long as we beat the kiwis I will be happy anyway |
March 29, 2015, 08:16 |
Rep Power: 17 |
Thanks Glenn,
Ok - so its for my PhD thesis ... So you would recommend the easiest method is to set up a report and then extract the images from there, rather than looking into CCL and session files? As you know (i read your thesis a year or two ago), while i am not looking for a free pass in the post processing, given the other efforts for the project, i am looking for the most effective / time-economic approach to get out the sets of images i need. I am happy to learn CCL, but not really if its overkill ... what would you recommend? 1) predefined views using CCL / session files OR 2) setting up a report Many thanks in advance cheers jon PS - you guys just did win - dont you get tired of just winning everything? |
March 29, 2015, 08:27 |
Rep Power: 17 |
Ok,
so - session files look to be the bomb and can be edited nice and easily - this (hopefully i am not being prematurely optimistic) is exactly what i need. thanks very much, now hopefully they can be run from the command line so i can write a batch file, and 'set and forget'. thanks a lot for your help, take care cheers jonathan |
March 29, 2015, 08:40 |
Rep Power: 144 |
Yes, you can run session files from the command line. So this gives you a method of generating a number of output results from a single command line.
Aussies never get tired of annoying kiwis. |
March 29, 2015, 08:47 |
Rep Power: 17 |
camera view, cfd-post, contour plots, tcl |
The FOAM Documentation Project - SHUT-DOWN | holger_marschall | OpenFOAM | 242 | March 7, 2013 13:30 |
How to make code run in parallel? | cwang5 | OpenFOAM Programming & Development | 1 | May 30, 2011 05:47 |
Open Source Vs Commercial Software | MechE | OpenFOAM | 28 | May 16, 2011 12:02 |
Small 3-D code | Zdravko Stojanovic | Main CFD Forum | 2 | July 19, 2010 11:11 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 06:59 |
