mesh around cylinder (3D)
Old   March 25, 2015, 20:47
Default mesh around cylinder (3D)
Beril
Beecee is on a distinguished road
I am trying to simulate 3D flow around a circular cylinder, and at the moment for the mesh I have used inflation whereas I want to add refinement as well, around the cylinder. Should I divide the block in divisions to refine the flow behind the cylinder and around it or is there a way I can do it by selecting the cylinder and adding refinement? (which didn’t work when I selected the surface of the cylinder)
thank you
Beecee is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 10, 2008 00:02
ICEM block mesh with a ball in a cylinder tube Li CFX 6 August 11, 2008 06:44
mesh problem for cylinder akr FLUENT 1 January 30, 2007 00:43
