Rep Power: 11 ![]() |
I simulate one passage of stay vane and guide vane and one runner passage. Normally, i use an average static pressure in outlet (located at a reasonable distance below the runner) in order to allow to the pressure profile to vary but i would like to know the context in which a boundary condition of radial equilibrium is used ? Also, if i put a boundary condition of radial equilibrium and that this is not the case in reality, this will involve a specific case of this condition that is dp/dr = 0 meaning constant static pressure. Is that right ? Moreover, I read on this post (http://www.cfd-online.com/Forums/cfx...ressure-2.html) that the radial equilibrium theory is only valid in the blade passages but it's wrong no ? For me, it's only valid upstream and downstream of the blade passage because all transport in radial direction are rightly done in this region. Thank you for your help |
Nobody can help me ?
Radial Equilibrium Pressure Distribution | Ema40 | FLUENT | 1 | November 12, 2014 17:52 |
new radial equilibrium pressure BC for turbomachinery | Jonathan | OpenFOAM Programming & Development | 8 | January 6, 2014 21:01 |
Radial Equilibrium pressure BC | sivakumar | OpenFOAM Running, Solving & CFD | 5 | September 25, 2013 09:40 |
Paper Radial Equilibrium | apoorv | Main CFD Forum | 0 | February 18, 2011 06:01 |
use of radial equilibrium press. in 2 phase flow | James Willie | FLUENT | 0 | May 2, 2005 11:26 |
