Different results for symmetric flow of pipe sudden expansion
Like Tree8Likes
Old   March 27, 2015, 12:02
Farzin
FarzinD is on a distinguished road
Originally Posted by Thomas MADELEINE View Post
It is a one way coupling and the particles don't affect your flow, right ?
your problem seems to be based one the fluid and not the particle, right ?
Have you tried to run your calculation without the particle part ? only a steady state run of your fluid ? you should expect to get the same problem normally (if I understood correctly)
Yes, the particles do not affect the flow and the results without them should be the same. Actually, I was planned to do that simplification though haven't done that yet.
FarzinD is offline   Reply With Quote
Old   March 27, 2015, 18:21
Farzin
Latest modification I've done ended with these results:
-Decreasing timescale factor to 0.3: increasing velocity of the monitor point (expansion), for both half-pipe and whole-pipe.
-doubling the number of nodes [in axial direction]: increasing increasing velocity of the monitor point (just tried on half-pipe).
After doing all of the above modifications the velocity of the interested point (expansion) in half-pipe (which increased from 7.2 to 7.8 m/s) is less than the whole-pipe's velocity (9.5 m/s).
Old   March 28, 2015, 04:49
If this is a steady state simulation then the time step size (or time scale factor) is not important. Just the residuals and imbalances it gets to. Time step size is important for transient simulations only.
If changing your mesh size as you describe changes the result by that much it shows that you are a long way from a mesh insensitive simulation (which means the results of your simulation are not dependant on your mesh). You will have to do considerable mesh refinement to reach mesh insensitivity.
Old   March 28, 2015, 05:20
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Please dont get this the wrong way, but to me it just seems like this is leading nowhere.
Why dont you take one step back and really think about what you are trying to model and which boundary conditions you used.
The results for the full model and a half model have to be perfectly identical, especially for a simple setup like a pipe expansion.
Period.
As long as the results dont match exactly, there is no point in tweaking any solver setting or changing the grid spacing.
There must be something wrong with the setup.
It might be a good idea to draw a sketch with the exact boundary conditions you used for both models (including a coordinate system) and upload it here.
flotus1 is offline   Reply With Quote
Old   March 28, 2015, 07:50
No offence taken, I value constructive comments. But I think this thread is slowly heading in the right direction.
Yes I agree - when the two simulations you are comparing are solved with good numerical accuracy. If the simulations are solved with poor accuracy then the results can be almost random, and they will not be even close to identical. And that appears to be what is occurring here.
Farzin reported that tighter convergence got the results to get closer to each other - so this suggests to me that numerical accuracy is an issue here.
I do agree with your final point - it would be good to show the exact setup to check there is no fundamental error in the setup. Note that I am not saying there is no fundamental setup problem, I am saying there is a numerical accuracy problem and there might be a fundamental setup problem.
Old   March 28, 2015, 09:39
flotus1's Avatar
Alex
So we both agree that there is some fundamental error here
Let me modify my initial statement from "it just seems like this is leading nowhere." to "maybe we are searching in the wrong place."
Old   March 28, 2015, 16:26
Farzin
I doubt that the mesh refinement can solve the problem. Because the velocities' changes are in the order of 0.1 but the difference between the cases are in the order of the 1.
Though I recently found that mesh refinement has a different effect on two cases and doubling the number of nodes for whole-pipe caused the monitor point's velocity decrease from 9.47 to 9.2m/s. (The half-pip which have about half amount of mesh elements, velocity at this point equals to 7.8m/s.)
This is the conditions of the flow for both cases I'm trying to simulate:
And this is the CFX-pre ccl files of two cases:
PipeExpansion_CCLs.zip
Old   March 28, 2015, 17:33
flotus1's Avatar
Alex
Still not quite the complete description of boundary conditions I expected but...
Are you really using a velocity boundary condition for inlet and outlet?
Old   March 28, 2015, 17:57
Farzin
Yes, I'm using velocity components for both inlet and outlet.
Actually in the previous work of others (Nugroho, 2001) which I'm intending to do, the mass flow rate is given. I assumed the fluid is incompressible and calculated these velocities, which are nearly the same as velocities computed in that study.
The table of parameters used in that study has come below:
Old   March 28, 2015, 18:10
flotus1's Avatar
Alex
With two velocity boundary conditions, the problem is ill-posed.
Use a pressure boundary condition at the outlet instead.
FarzinD likes this.
Old   March 29, 2015, 19:01
Farzin
After choosing discharge-to-atmosphere as outlet boundary condition, with the coarse grid I used at first, velocity at the expansion plane for both cases is nearly the same (5.3712 against 5.3713 m/s).
However, there is much more modifications to do to reach an accurate result and the outlet condition of the study mentioned before is unclear to me, the problem that initiated this discussion is solved.
Thank you Alex, Glenn and Thomas. I learned much during these tries and errors.
cfx, particulate flow, pipe expansion
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 05:13
No Fluctuatios in LES results for pipe flow!!! Roohi CFX 5 September 7, 2011 19:50
Sudden expansion kmgraju CFX 3 July 28, 2011 19:35
Disturbed flow field at outlet boundary (Multiphase flow through pipe) Michiel CFX 17 April 21, 2010 11:14
Rarefied Flow through sudden expansion applemango Main CFD Forum 0 April 16, 2010 07:08
