Multiphase analysis of Humidifier using ANSYS-CFX |
Suraj Marale
Rep Power: 11 ![]() |
I am working on CFD analysis of humidifier. In this two fluids (Air and water) are mixing and the heat and mass transfer will takes place. Water and air are in counter flow. I am using Ansys-CFX for the simulation. Please help me for this, I don't know how to solve the multiphase problem in CFX. ![]() Do anyone have idea about this? how to do the analysis of this in ANSYS-CFX? Thanks in advance.... ![]() |
Rep Power: 144 ![]() ![]() ![]() ![]() |
Have a look at the tutorial examples in CFX and on the ANSYS customer page. Do lots of reading into the multiphase models - they are quite complex and if you do not understand them then you have no hope of getting this working. The model you propose is quite complex so expect to have quite a bit of work to do to get up to speed.
Suraj Marale
Thanks for reply horrocks...
![]() Do you have any idea about the porous media. In my problem i am defining one region as porous. I know how to solve the porous media with single fluid but i don't have idea if there is multiphase. Anyone is having idea about this please reply???? Thanks.. |
Assam
Rep Power: 0 ![]() |
hii guys,
I am working on dehumidifier (air and liquid dessicant) flowing through single domain ,i have to work for heat and mass transfer between air and solution .so which model i should use plz help as i am new in ansys . Thanks in advance |
I got code 1 error from ANSYS CFX | zlor1324 | CFX | 0 | March 11, 2014 19:22 |
how to map resultd from cfx to ansys? | ritesh | CFX | 2 | June 1, 2011 07:52 |
Aerodynamic noise analysis with CFX | famarcfd | Main CFD Forum | 0 | December 14, 2010 07:53 |
Electronics Enclosure Analysis with CFX | Simulation Engineer | CFX | 1 | April 22, 2009 11:08 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 01:10 |
