Anthi Gkesouli
Rep Power: 14 ![]() |
I am trying to simulate a quasi 2D and two phase (water -air) settling tank. I use the homogeneous model to model the air - water domains and the ASM model to simulate the solids.
Firstly, I run the two - phase tank without solids and the solution converged. However, when I tried to run the model with solids, the run is terminated with error after approximately 1000 iterations. I attach the error: Parallel run: Received message from slave ----------------------------------------- Slave partition : 3 Slave routine : ErrAction Master location : RCVBUF,MSGTAG=1214 Message label : 001100279 Message follows below - : +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Floating point exception: Overflow | +--------------------------------------------------------------------+ Parallel run: Received message from slave ----------------------------------------- Slave partition : 3 Slave routine : ErrAction Master location : RCVBUF,MSGTAG=1214 Message label : 001100279 Message follows below - : +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine FPX: C_FPX_HANDLER | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | The following transient and backup files written by the ANSYS CFX | | solver have been saved in the directory | | C:/Windphd/Small/small_pending_tasks/dp0_CFX_Solution/Fluid Flow | | CFX_001: | | | | 0_full.trn | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The following user files have been saved in the directory | | C:/Windphd/Small/small_pending_tasks/dp0_CFX_Solution/Fluid Flow | | CFX_001: | | | | mon | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Warning! | | | | After waiting for 60 seconds, 1 solver manager process(es) appear | | not to have noticed that this run has ended. You may get errors | | removing some files if they are still open in the solver manager. | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. I have read the FAQ and the relative before answeared threads in the forum, so I tried the following: 1.) Double precision. 2.) Minimizing the timestep. 3.) Changing the mesh. Nothing worked. Any other idea that could possibly help me? Since the run converged without solids, I believe that something is happening with ASM model. Has anybody used ASM model combined with homogeneous model? Thanx a lot in advance Anthi |
Rep Power: 144 ![]() ![]() ![]() ![]() |
I have never tried that combination of models.
I would output a backup file before it crashes. Then have a close look in the post-processor and see if you can find something which is going haywire. That will give you some clues for where to look. Just a thought - ASM with a homogeneous free surface model could end up with some strange results - like solids flying out of the liquid phase and into the solid phase. You might need something more sophisticated than ASM. But I could be wrong. Just a thought. |
Anthi Gkesouli
Thanx for your advice.
Do you have any idea about the model that I could try for simulating the solids? |
I was thinking of just a normal eularian-eularian multiphase model.
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 10:08 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 14:40 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
Multiphase analysis | dev325 | CFX | 6 | April 14, 2010 07:09 |
Multiphase High pressure nozzle analysis | Anant | FLUENT | 0 | December 20, 2005 02:37 |
