March 22, 2015, 13:44 |
3D flow past cylinder simulation
Beril
Rep Power: 11 |
Hello everyone,
I am simulating 3D laminar flow around a cylinder on ANSYS CFX and have to look at the FFT graphs for different velocities all in the range of laminar flow (max Reynolds number is 1000). Should I write an expression for the velocity as a function or put in the velocities individually (when I do that I can't set the turbulence settings off and make it laminar - How do I fix that?) Also, how should I find the vortex shedding frequency for different velocities? I have difficulty plotting the graph of amplitude against time and flow velocity against time. Lastly what is the best way to do this simulation (will have to move on to the pulsating flow in the next steps) Thank you so much for your help! |
March 22, 2015, 17:09 |
Rep Power: 144 |
I do not understand your first question.
The simplest way to find the shedding frequency of the von Karmen vortex street is to put a monitor point in the middle of the wake, a diameter or two behind the cylinder. Get the monitor point to output velocity or pressure. Then export the monitor point data and do an FFT on it to get the frequency. Your final question makes about as much sense as "how do you design a spaceship". |
ansys, cylinder, fluid dynamics, frequency, vortex shedding |
Fluent + flow past cylinder at Re=40 | m.vegad | Main CFD Forum | 25 | January 9, 2018 00:34 |
Flow past a cylinder. Help needed | Lurapa | Main CFD Forum | 1 | August 18, 2013 11:25 |
Drag Coefficient for flow past a Cylinder | o_mars_2010 | Main CFD Forum | 0 | April 18, 2013 06:17 |
FLUENT, flow past a circular cylinder | Paul Reichl | Main CFD Forum | 16 | December 8, 2012 15:21 |
CFD help: flow past cylinder | harsha00711 | Main CFD Forum | 1 | December 24, 2010 21:19 |
