blast simulation, blast wave, pressure wave simulation
Old   March 22, 2015, 05:59
Post blast simulation, blast wave, pressure wave simulation
dewangga yudistira
dydewangga is on a distinguished road
hello
I'm trying to make blast simulation, in this case deflaragation / pressure wave blast of hidrocarbon (I used C1 as the fluid)
the simulation will be used transient function, is it better use cfx or the transient?
for the inlet boundary i will use sphere with pressure based on some function, can I input the function in ansys cfx?
i want to use 450 m/s with overpressure function of blast 0.35 bar and temperature 279 C , can I input it in the inlet of ansys cfx?
and i still dont understand, must i use outlet boundary condition with 0 m/s velocity or using an opening as my outflow?
dydewangga is offline   Reply With Quote
Old   March 22, 2015, 07:13
Yes. Have a look at 1D interpolation functions, or CEL expressions.
Look in the CFX documentation for the available options for supersonic inlets.
You can use any boundary condition you like. As I do not know what you are modelling I cannot assess how suitable the options you list are.
But you cannot define an outlet with 0m/s velocity - then no flow will occur.
If this blast is to occur in a far field then an opening with zero relative pressure makes sense.
Old   April 7, 2015, 12:20
dewangga yudistira
thank you ghorrocks
I'm already finished for the model, Im using point of blast as a sphere model
to make it supersonic I must used fluid whose density is a function of pressure, like CH4 or some gas phase hidrocarbon and set the fluid models>heat transfer as total energy right?
for the outlet I still confuse, must I used outlet or opening for boundary condition, for a distance I want to make the pressure and velocity normal
the blast simulation i want to make start from ignite point of blast ( i modelled as sphere) with 450 m/s (supesonic) 1.33 bar pressure and then for some radius the pressure and velocity will be normal
must i using some CEL to define my boundary case?
Old   April 7, 2015, 22:23
Your domain looks like minecraft. My kids like blowing things up in minecraft as well
Yes, for a compressible flow you need to use total energy as the heat transfer model.
An alternative to the outlet you can looking at is you can also do this using a source point. This is probably a better way of doing it if you want the explosion to start at a small point.
Old   April 11, 2015, 03:52
dewangga yudistira
for the first i want to simulate simple model, if it works i will make it more complicated
I have some reference to do my simulation, but I still didnt understand how to input the parameter, can you help me to understand it ghorrocks? is it neccessary to using CEL to define the parameter?
link
http://journals.ajaums.ac.ir/files/s...-8-252065f.pdf
the simulation using transient analysis, but i dont get it how to generate blast shock wave from the inlet, please help me ghorrocks
Old   April 12, 2015, 08:50
I would recommend using a mass source point, not an inlet for this. Give that a try first.
Old   April 15, 2015, 23:15
dewangga yudistira
thanks for answer my question ghorrocks
mass source? can you give me more explanation or example?
I still not understand how to set mass source for the inlet
Old   April 16, 2015, 04:50
Have you tried the CFX documentation?
Old   April 16, 2015, 21:55
dewangga yudistira
I read some of tutorial, which one did you mean?
Old   April 17, 2015, 06:44
I do not think any tutorials use source points. The modelling guide and other documentation explains them well.
Old   April 25, 2015, 09:23
dewangga yudistira
I'm not too understand at all ghorrock
can we define an expression like this mathematical function for the inlet
with Po=10MPa, and theta 1 ms to get this plot for the inlet
I hope you can help me
Old   April 26, 2015, 20:33
The mass source approach requires a mass flow rate to be defined. Your function defines a pressure function. So that function is easy to implement at an inlet, but will require transformation to a mass flow rate if you want to use the mass source point approach.
Old   April 26, 2015, 23:43
dewangga yudistira
is that means i need to define mass flow rate as my inlet? I have the information for the mass flow rate
I also want to define the changes of pressure of blast from time
the pressure function that i show you in my last reply will give this kind of result, I read it from dissertation publication
i wonder how can he define the inlet to make this kind of simulation in cfx
any suggestion?
Old   April 27, 2015, 07:06
You cannot prescribe BOTH pressure and flow. To do so is a badly posed boundary condition. You can only prescribe one, and then you check the other is what you expect as a check things are working properly.
blast, blastwave, cfx & fluent, define, function of time
Pressure for wave height in an Water Wave Tank Cluain CFX 8 December 6, 2021 04:58
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Setting up the pressure variation due to tornado in a duct(UDF)+animation guillaume1990 FLUENT 0 March 3, 2014 12:59
Re: Pressure wave simulation taha Main CFD Forum 0 August 23, 2004 11:55
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
