Transient wall shear not available in CFD Post |
March 20, 2015, 15:26 |
NC
Rep Power: 11 |
I took care to include Wall Shear as an extra variable to keep in Trn results, but when I tried to plot a contour at the transient time steps, nothing shows up (i.e. the wall is simply transparent). The same when I tried just the X,Y, or Z components. However, the contour does show when I choose the final time step. What is going on here? Thanks.
March 21, 2015, 14:05 |
A clue
NC
Rep Power: 11 |
I hope this is a clue as to why the Wall Shear is not available in my transient results, although it hasn't helped me. I set a monitor point for various variables in a transient run and the Wall Shear ones are excluded. I suspect the Wall Shear requires a somewhat different treatment than do most variables because it exists only on the wall, but how? I have verified that my specified location is indeed on the wall.
Monitor Point: WSS Domain: Default Domain User specified location (r,t,a) : 2.574E-03, 5.236E-01, 2.100E-02 User specified location (x,y,z) : 2.229E-03, 1.287E-03, 2.100E-02 Excluded variables from output variable list: Wall Shear X Wall Shear Y Wall Shear Z Valid variables from output variable list: Velocity u Velocity v Velocity w |
February 24, 2021, 03:43 |
Non-US/Non-Canadian
Rep Power: 11 |
I have the same problem. Do you know how to solve this problem? Thanks in advance. Regards, Mehrdad |
February 24, 2021, 04:45 |
M
Rep Power: 13 |
Sometimes its a bit tricky. I had a similar case once, where a derived variable didn't show, because another variabel was missing. You need the velocity gradient to calculate wall shear, so I suppose including it in trn files will enable Post to calculate wall shear.
Haven't used CFX in a while, so not sure if it can be included from the variable list. |
February 24, 2021, 11:58 |
Rep Power: 33 |
Woud you mind showing the output control setup for the transient file you requested?
cfd - post, wall shear stress |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 16:33 |
Wall Shear on concave plate | sherifkadry | CFX | 7 | April 26, 2013 11:07 |
Fluid wall shear stress | Sinead Kelly (Kelly) | OpenFOAM Running, Solving & CFD | 2 | March 30, 2011 07:41 |
What is the detail definition of wall shear stress | zjm | FLUENT | 0 | January 2, 2002 08:43 |
Flux depending on wall shear stress in Fluent 5.2 | Andreas Borg | FLUENT | 0 | June 7, 2000 07:27 |
