Average static pressure = 0
Old   March 19, 2015, 11:57
Default Average static pressure = 0
MissCFD is on a distinguished road
Can anybody tell me why specifying average static pressure = 0 or 101325 or any other value has the same effect ?
Thank you for your help
MissCFD is offline   Reply With Quote
Old   March 19, 2015, 12:24
Thomas MADELEINE
Thomas MADELEINE is on a distinguished road
we will need a little more details to help you I think.
Where did you put average static pressure (Outlet I guess) ?
What was your other boundary conditions ?
What do you mean by same effect ? (all does not converge ? all results are the same ?)
what is the fluid you model ?
It is possible that pressure has no effect on your simulation. For example, water will not be really affected by pressure in outlet if you specify a velocity in inlet. The flow is incompressible, so the flow will be quite the same at 1 bar as at 2 or 3 bar (more or less)
Firstly, check the obvious solution :
Should it have some differences ?
Do you use the right units ?
Check the reference pressure ?
Thomas MADELEINE is offline   Reply With Quote
Old   March 19, 2015, 12:41
I simulate a passage of stator and a passage of rotor for a hydraulic turbine. So I use water.
I use a mass flow rate condition for inlet and pressure condition for outlet. My reference pressure is 1 atm.
I have tried three options in outlet: average static pressure = 0, constant static pressure (P=0) and equilibrium Radial. I don’t really see differences between these cases apart from equilibrium radial condition where total pressure at inlet is a little more important and a little less at outlet that the two others cases.
It isn’t very clear for me why water will not be really affected by pressure in outlet if you specify a velocity in inlet? Does that mean that it’s the inlet velocity that defines the pressure in my domain … ?
Moreover, it’s maybe a silly question but why I should impose an average static pressure = 0 and not 1000 Pa or 101300 Pa ? I have the same question with the constant static pressure.
Thank you again
Originally Posted by Thomas MADELEINE View Post
Old   March 19, 2015, 14:11
Thomas MADELEINE
massflow and velocity at inlet are the same kind of condition
pressure on water will not change the density nor the temperature and the viscosity. so basically when you change the outlet pressure the only thing that change (more or less) is the pressure (by the difference you set.
example
Run 1
P outlet = 1 bar
Ptot inlet = 1.4 bar
Ptot outlet = 1.1 bar
Run 2
P outlet = 4 bar
Ptot inlet = 4.4 bar
Ptot outlet = 4.1 bar
and the same velocity, work and other stuff for both simulation.
for the average static pressure, radial equilibrium, constant static pressure, look at the help in ansys it is quite simple.
simple model, difficult outlet Eric CFX 7 May 23, 2014 09:13
Assign static pressure at inlet Tanjina FLUENT 0 November 3, 2013 12:34
the static pressure at one outlet is negative? yuhehuan Main CFD Forum 7 August 15, 2013 22:01
UDF to control Static Pressure (in cylinder) James FLUENT 0 July 20, 2004 08:54
Total pressure to static pressure ratio roadracer Siemens 1 April 17, 2003 06:31
