Average Static Pressure : Over Outlet/Radial equilibrium |
March 17, 2015, 18:04 |
Rep Power: 12 |
- By way of explanation for this condition, the CFX-pre user’s guide gives the formula following :
P(ip) = Paverage(user) + (P(n) - Paverage(n)) where P(ip) is the imposed pressure at each integration point. I don’t understand what represent the local nodal value P(n) and the average outlet boundary pressure Paverage(n) ? Is P(n) the value at the center of control volume ? And what is the difference between Paverage(user) and Paverage(n) ? - For the radial equilibrium condition, I don’t see where I can specified the pressure for the radial reference position ? |
What BCs to set in Fluent when I know only the static pressure at Inlet and outlet? | nikesh | FLUENT | 0 | January 30, 2015 00:32 |
Assign static pressure at inlet | Tanjina | FLUENT | 0 | November 3, 2013 12:34 |
the static pressure at one outlet is negative? | yuhehuan | Main CFD Forum | 7 | August 15, 2013 22:01 |
UDF to control Static Pressure (in cylinder) | James | FLUENT | 0 | July 20, 2004 08:54 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
