Reference pressure and buoyancy density of simple pipe flow
Old   March 12, 2015, 20:45
Exclamation Reference pressure and buoyancy density of simple pipe flow
dotapro is on a distinguished road
I'm trying to model 100m long pipe flow with a hole release of 0.1 m diameter whereby methane is flowed from inlet with mass flow rate of 6.178 kg/s and 26.58 Celsius. The outlets are the release from hole and pipe outlet with 0 Pa static pressure. May I know what value I should put for reference pressure and buoyancy density? Should I consider pgh in this case? Thanks for your help.
dotapro is offline   Reply With Quote
Old   March 12, 2015, 21:08
The reference pressure should be a typical pressure in the device. If the outlet is 0Pa (relative to atmosphere I presume) then 1 atmosphere should be OK for reference pressure.
Read the documentation and the examples about how to handle the hydrostatic head.
Old   March 12, 2015, 21:21
Thanks for your reply. What happens if my outlet is relative to water instead of air ? Again, what value for I should input for reference pressure and static pressure outlet?
Old   March 12, 2015, 23:37
I do not understand your question.
The reference pressure is a typical absolute pressure in your domain, so the simulation can use a variance from this reference pressure as the pressure variable. When the pressure variable is minimised you minimise round off errors.
Old   March 13, 2015, 02:47
My apology for not clarifying it clearly and lengthy message. I trying to model subsea gas release whereby my first simulation consists of simple pipe flow as stated above while my second simulation is methane releases from hole into the sea water.My inlet pressure,P1 is 28 bar. So, my question is reference pressure should be calculated using bernoulli's pressure drop in circular pipe equation where ∆p=fxL/D xρ/2xV^2, pipe outlet static pressure is P2 = P1 - pressure drop, and my hole release static pressure is assume to be 0 Pa . Is my assumption correct?
Old   March 13, 2015, 05:07
I still do not understand what you are saying. Where does the Bernoulli equation come into it?
It sounds like you simply need to set the reference pressure to the ambient water pressure at the depth you are modelling. Then all pressures will be relative to that reference pressure.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
error message cuteapathy CFX 14 March 20, 2012 07:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
