March 12, 2015, 02:55 |
Bug in Workbench CFX
Pierre
Rep Power: 11 |
There’s one bug of Workbench CFX bothering me for a long time. It shows up sometimes occasionally, not usually. I have no clue about what causes this bug to show up and how to avoid it. Hope someone could help.
I use Workbench CFX ‘Parameter Set’ table (figure1) to calculate and output simulation results directly from different initial condition set (called ‘design points’ in CFX). But occasionally, as calculations of different design points are done, the table shows wrong output results which are all the same for different design points (figure2). But if I turn on the CFX solver at Workbench in the middle of the simulations, I can see that the simulations actually read the correct input values. So the simulations are correct. It seems that, when the simulations are done, Workbench just give outputs parameter value from a same result file which doesn’t correspond to the design point, thus the simulation, which was just calculated. When this happens, I always save the Workbench project as another file by clicking on the button ‘save project as….’Then I rerun the Workbench, the bug disappears. But I really want to avoid this bug at the very beginning of the Workbench simulations. Could anyone tell me what’s the original of this bug and how to avoid it? If there’s anything not clear in my question expression, please let me know and I will make it clear. Thanks. |
March 12, 2015, 04:55 |
Rep Power: 144 |
If you have found a bug you should report it to ANSYS. That is the only way to get it fixed.
Also make sure you are running the latest version (V16). ANSYS will not care if you have found a bug in an old version. |
March 12, 2015, 05:16 |
#3 | |
Pierre
Rep Power: 11 |
Btw, it happens to me a lot of times. You have never got this problem? |
March 12, 2015, 05:20 |
Rep Power: 144 |
If you are reporting a bug you are helping them. Hopefully they will listen to you.
I rarely use workbench . I use CFX stand-alone most of the time. |
March 13, 2015, 09:37 |
#5 | |
Pierre
Rep Power: 11 |
July 13, 2017, 17:18 |
Chaitanya Mokashi
Hi, did you find a solution to this problem? I am also facing the same issue, the workbench parameter table updates the same value for all design points.
Thanks in advance! Chaitanya |
August 2, 2017, 01:18 |
Rep Power: 11 |
I think you need to make sure you select "Use as workbench parameter" in cfx pre, and run simulation, and then in post, use as workbench output parameter. Then fill in your table. Pretty sure if you do it all in cfx-post, the input parameters don't get passed to CFX pre, so it never really varies the input parameter.
Sent from my iPhone using CFD Online Forum mobile app |
Remeshing in CFX using workbench meshing. | adeban | CFX | 25 | March 29, 2021 06:46 |
parametric analyses in ansys workbench and CFX | hmasenger | CFX | 25 | April 20, 2016 05:05 |
Qustion about CFX expression bug | Anna Tian | CFX | 4 | May 12, 2013 20:29 |
CFX - Pre and Workbench License issues | CFX user | CFX | 2 | August 12, 2009 17:59 |
Import Fan 3D Model - Workbench or CFX? | Stewart Long | CFX | 2 | October 28, 2008 05:05 |
