CCL and Perl syntax
Old   March 10, 2015, 11:26
Default CCL and Perl syntax
Mickael
Leackim is on a distinguished road
I am currently using CCL and Perl to make a post treatment file.
I would like to know if someone already managed to used CCL syntax inside a perl .pm file (library file).
To explain a little more, when i am writting my .pm file i can't use !,
So how i show CFX that some commands are CCL.
Here is an example :
package Cfx;
use strict;
use Exporter qw(import);
our $VERSION = 1.00;
our @ISA = qw(Exporter);
our @EXPORT = ();
our @EXPORT_OK = qw(PointXYZ);
our %EXPORT_TAGS = ( DEFAULT => [qw(&PointXYZ)],
All => [qw(&PointXYZ)]);
COMMAND FILE:
CFX Post Version = 14.5
END
sub PointXYZ{
my ($s_dom,$s_x,$s_y,$s_z,$s_unit,$s_name)=@_; # Subroutine Input
my ($r_name);
# ------------Variable Initialization-----------------------------------------------------------------------------------------------------#
$r_name="";
POINT:Point $s_name
Apply Instancing Transform = On
Colour = 1, 1, 0
Domain List = $s_dom
Line Width = 2
Option = XYZ
Point = $s_x $s_unit, $s_y $s_unit, $s_z $s_unit;
Point Symbol = Crosshair
Range = Global
Specular Lighting = On
Surface Drawing = Smooth Shading;
Symbol Size = 0.07
Transparency = 0.0
END;
$r_name="/POINT:Point $s_name"; #/
return($r_name);
1;
As soon as i add CFX command (CCL) like POINT... my code stop working, however if i removed any CFX line and make just "print" things, my library works.
So,if someone find a solution to mix perl and CFX language let me know.
Thank you
Leackim is offline   Reply With Quote
Old   March 10, 2015, 11:37
Opaque will become famous soon enough
Have you looked in the installation directory for CFD-Post session file examples ? They are suffixed .cse (Cfx SEssion)
They are worth a fortune if you are interested in Perl+CCL
Opaque is offline   Reply With Quote
Old   March 11, 2015, 14:51
Edmund Singer P.E.
singer1812 is on a distinguished road
Why do you have ; on END and Point = $s_x $s_unit, $s_y $s_unit, $s_z $s_unit
Those are CFX commands, not Perl
singer1812 is offline   Reply With Quote
CCL CFD post: use of common perl function Leackim CFX 1 January 23, 2017 09:37
Access to arrays of variables with CCL or perl in command editor omidiut CFX 2 October 18, 2011 06:13
Perl script for intialisation pratik mehta CFX 2 September 10, 2008 04:09
CFX5Post error in batch mode with Perl windhair CFX 2 March 20, 2007 06:41
Time-steps via Perl in CCL Rui CFX 5 March 29, 2004 01:47
