Centrifugal pump performance analyzing
Old   March 9, 2015, 00:53
Lightbulb Centrifugal pump performance analyzing
Vinoth
Vinothrengaraj is on a distinguished road
Can anyone explain the solution for solving below mentioned problem...
I am using ANSYS14.5 CFX to analyze centrifugal pump performance. The impeller (Rotor)and casing (Stator) are designed as the fluid domain model and saved in IGES format. WHen it imported in CFX tool , it automatically created the interfaces between these parts.
The interface option is chosen as FROZEN ROTOR and it pitch angle option is chosen as AUTOMATIC. At the time , the error is shown.
The error message:
The interface , the pitch angle ratio(1.09) is not same as the area ratio(4.62)
Vinothrengaraj is offline   Reply With Quote
Old   March 9, 2015, 13:28
Jesus Contreras Espada
jcespada is on a distinguished road
Have you checked the Rotation axis?
jcespada is offline   Reply With Quote
Old   May 4, 2016, 03:47
alireza esmaily
kaktus10 is on a distinguished road
The error message:
By Facing each other at the Surfaces of the Rotor and Stator the problem will solve.
kaktus10 is offline   Reply With Quote
domain interface, frozen rotor
centrifugal pump Chalghoum CFX 18 April 16, 2014 07:37
Autoblade centrifugal pump template mahdi balali Fidelity CFD 3 February 18, 2014 09:56
Centrifugal Pump Cavitation problem or not. ismael.s CFX 13 February 27, 2012 09:00
[GAMBIT] influence between angle in impeller blade and centrifugal pump performance barak182 ANSYS Meshing & Geometry 2 August 18, 2010 04:07
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 04:20
